J jumbo New member Equipment b2650 Dec 11, 2019 10 1 3 49854 Jan 11, 2026 #1 b2782b snow blower fan shear bolt and bolt gone where does the shear bolt go two differant holes which one is for shear bolt Last edited by a moderator: Jan 11, 2026
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 35,585 10,680 113 Sandpoint, ID Jan 11, 2026 #2 Which one are you having an issue with?
D Dustball Well-known member Equipment 2016 B2650HSDC Sep 15, 2023 512 380 63 Hudson, WI Jan 11, 2026 #3 This is the shear bolt-
J jumbo New member Equipment b2650 Dec 11, 2019 10 1 3 49854 Jan 13, 2026 #4 Dustball said: This is the shear bolt- View attachment 168169 Click to expand... dustball thanks and would you know the hardness # of this bolt.
D Dustball Well-known member Equipment 2016 B2650HSDC Sep 15, 2023 512 380 63 Hudson, WI Jan 14, 2026 #5 jumbo said: dustball thanks and would you know the hardness # of this bolt. Click to expand...
G GreensvilleJay Well-known member Equipment BX23-S,57 A-C D-14, Apr 2, 2019 13,766 6,246 113 Greensville,Ontario,Canada Jan 14, 2026 #6 You can use any grade 5 bolt by modifying it . Chuck in a drill then use hacksaw to create a shallow groove at the 'shear line'. That's the gap between the two mating blower parts. Reactions: 1 user
