SB1064 Shear Bolt Question
Trustable
l2501HST
Jul 5, 2022
272
222
Hi All, I have a SB1064 on order from a local dealer and bought some shear bolts for the driveshaft while I was there. If this is a new machine that LP is shipping to them, would the serial number be 881641+ or 881640-. Im thinking they wouldnt be able to get me the serial number until its delivered so maybe one of you is more familiar with how it works. If its the + I have the correct shear bolts but if its the - they gave me the incorrect ones.
What they gave me was 802-604c (HHCS 5/16-1 D 3 B) and 803-084c (NUT HEX NYL D 3 B). In the manual for 881641+ this is correct, but In the 881640- operators manual it states the part numbers are 802-005c (1/4"-20 x 1" GR5 hex head cap screw) and 803-255C (1/4"-20 Nylock hex nut). If anyone has any advice I would really appreciate it, this is my first attachment that utilizes the PTO so I want to ensure I have plenty of extra shear bolts for the driveline and the driveshaft of the snowblower beforehand.
9,884
Yea, there is no way for us be able to tell you what serial number the dealer will get and give you.
BAP
Dec 31, 2012
3,083
1,214
Also, if you are looking at the owners manual to get your information, they aren’t updated as frequently, as production changes are made to the equipment.
Trustable
l2501HST
Jul 5, 2022
272
222
wait ... your driveshaft has a shear bolt? like, the main drive on the thing?
I don’t have it yet but based on the manual it looks like the PTO shaft has one. The manual calls it driveline and driveshaft. One is PTO one is auger.
Trustable
l2501HST
Jul 5, 2022
272
222
I was also able to contact the dealer. When landpride uses the + or “after” it means its new and in production. any implements with a - means it’s no longer being made
3,767
Trust me on this …. If you don’t have the machine yet…. you don’t need shear bolts.
Wait until you get the machine to see what it needs. ;)
Trustable
l2501HST
Jul 5, 2022
272
222
Yeah I hear ya. Probably the smarter choice. I was Just worried about getting it, then getting dumped on with snow, then snapping a bolt because I’ve never used a PTO attachment.
3,767
A common mistake is using the “incorrect” (harder/stronger) grade 5 or 8 bolts for shear bolts.
That is a good way to seriously damage equip’t and perhaps even hazard the tractor/pto.
I believe it’s best to use the OEM part …or a Grade 2. YMMV
Trustable
l2501HST
Jul 5, 2022
272
222
Yeah I agree. I’m only doing oem Parts. Weirdly enough the one for the auger is actually grade 8. Specified in the manual as well as part diagram.
