Kubota M100 3-point hitch
kub100
Kubota M100
Feb 20, 2021
Leader Sk. Canada
Light flashing quickly for 3 point hitch, replaced hydraulic control sensor and lift arm sensor, worked perfect last year, now light just flashes and possibilities are the speed switch for up and down, 1-9 limiter, and the depth resistance switch, $2200 worth, and am not sure if that would cure the problem. The switch on back of fender will lift 3-point hitch up and down, the one on the counsel will not. Any suggestions.
11,222
Have you looked at the WSM to see what it says?
3,143
WSM = Work Shop Manual (repair shop manual)
