3 phase converter.... Deal or No?
John T
2017 BX23S
May 5, 2017
1,215
750
under a rock
I see one of these for sale locally.... for $150 bucks.....
I know nothing about converters and have no need for one.....
But, I'm not against making a few bucks flipping it.... :ROFLMAO:
any thoughts?
heres a link to the unit new...
cliffboyer
L3301 w/LA525 loader, G5200 mower w/RC48 deck, Kawasaki 610 Mule, DR mower
Nov 30, 2017
276
76
Southern IL
Certainly a steal at that price. Could be flipped for a decent return, but would it worth the time dealing with potential buyers & scammers?
John T
2017 BX23S
May 5, 2017
1,215
750
under a rock
Wondering more if this is a desirable unit.... and is it a good option for someone looking for 3 ph power ......
Running with scissors had a thread and lots of options were talked about...
any opinions on this unit?
4,825
No question that I would buy it for 150 bucks.
Kind of a “niche” market though……….Out of all the people I know personally, I’m the only knucklehead that would be interested………. (Hell, none of my friends even know what 3 phase is, but they can recite the batting average of the Dallas Cowboys from memory…….:ROFLMAO: )
I think I am going with a VFD, but for that kind of money, I might be swayed…...
I do not know anything about that company though.
6,620
Thats a great deal if all you need is 5HP.
Reading the technical description its designed for powering hard starting loads like an air compressor. It has logic that repeatedly cycles start caps into the circuit at the zero point on the phase transitions. Thats a new idea to me and I have no idea if it works as claimed. Seems like cap life would be shortened considerably.
John T
2017 BX23S
May 5, 2017
1,215
750
under a rock
Did you happen to read what the Minimum starting HP was?
My buddy has a one similar (different brand) and it's 3hp min / 5hp max
It will not start his lathe unless he turns on his Bridgeport....
6,620
I just skimmed the blurb. I dont understand why there is a minimum. Can you explain the starting process.?
John T
2017 BX23S
May 5, 2017
1,215
750
under a rock
I'm not sure about any of this... I am pretty much ignorant to anything 3PH
But I happened to be talking to a friend of mine ... to quiz him on value of this one...
and he asked about min HP
Then told me about HIS converter and how it won't start unless he has over 3HP draw.
6,620
A normal RPC is started before any load motor. Once the RPC is up and running you start one or more load motors. The RPC simply supplies 3P power and knows nothing about the load motors.
3,969
For “investments” ….most things…of which I’m not familiar…. I stay away from.
I see too many examples of folks who actually DO know about the item…. who lose their shirts anyway.
In most cases, It takes a person thoroughly knowledgable about the product AND it’s marketplace to successfully “deal” in them.
I’d suggest you simply observe what happens with this seeming bargain …and, for educational fun, see what transpires.
John T
2017 BX23S
May 5, 2017
1,215
750
under a rock
What would explain why he can't start a 1HP lathe before turning on a 3HP Bridgeport mill?
seems odd.
thats why he was assuming there was a 'minimum' HP ...... just like the Maximum HP (5 HP)
John T
2017 BX23S
May 5, 2017
1,215
750
under a rock
Too Late.
I got a hair trigger.... 🔫
6,620
Too Late.
Your investment is sound.
I dont know why there is a "minimum load requred" on your friends RPC. A normal RPC is started with ZERO load - e.g no loads connected. Loads are then started or stopped with the RPC running.. The nameplate on this one clearly says no minimum.
John T
2017 BX23S
May 5, 2017
1,215
750
under a rock
I dont know why there is a minimum load requred on your friends RPC. A normal RPC is started with ZERO load - e.g no loads connected. Loads are then started or stopped with the RPC running.. The nameplate on this one clearly says no minimum.
Actually I just asked him again and he said HIS faceplate says HP range 1hp-3hp
and his lathe is 1/2hp
He also said his converter does not run on a motor ... it "fakes the 3rd leg"
it's called a 'Phase-A-Matic' brand.
6,620
He does not have a rotary phase converter. He has some sort of static converter. I would guess his problem is the motor on the lathe - it wont start on a static converter. Why I dont know.
When he turns on the mill the mill motor acts like an idler and effectively turns the static converter into a rotary converter.
Phase-A- Matic is one of if not the biggest names in the business.
6,620
Tell him you will sell him a REAL converter at a bargain price :p
John T
2017 BX23S
May 5, 2017
1,215
750
under a rock
Thanks,
that makes sense.
