Bx23 4 wheel drive coupler
dvto2
Bx23 and implements
Feb 26, 2019
110
12
east granby
2003 BX23. The coupler between my rear and front wheel drive shaft get off yesterday. Any tricks to reinstalling a new one?
3,029
What in this picture is "off?"
dvto2
Bx23 and implements
Feb 26, 2019
110
12
east granby
It’s part 160, the universal assy joint. It looks like it locks in with a pin spring. I ordered this from messick’s today. I was just wondering if there were some tips that might be useful. I’ll lube it with grease before I put it on.
3,373
I wouldn’t call this a tip, but something to think about. I believe I read that the spring pins have a proper orientation when you put them in. I believe the slot in the pin is supposed to point along the length of the shaft that U joint is mounted on. What I remember is that this allows the pin to flex a bit. If the slot is perpendicular to the direction of the shaft then flexing can cause breakage of the pin over time.
This seemed logical to me so that’s probably the reason I remember it. I had the U-joint on the shaft that drives my mid mounted mower deck fall off, due to a broken pin. When I installed the new new joint I put the pin in as described above. Whether it makes a difference or not I don’t know. I figured why not do it that way…
Side note: After I installed the new U joint I bought, I found the old one laying on top of the mower deck along with some grass clippings that were hiding it…:D
dvto2
Bx23 and implements
Feb 26, 2019
110
12
east granby
Exactly the kind of to tip I was looking for. Thanks much.
