Trenching and postholes in hardpan
selftot
L3400
Aug 6, 2025
46
Vancouver Island
I need to run some trenches and install posts in hardpan. Lots of gravel and rocks packed into the hardpan.
What is the best tool(s) for the job ? I have an L3400 and BH75 backhoe.
My 12" bucket can get the job done slowly. An auger just breaks shear pins.
I was looking at the BX Extended quick attach and Ripper but i'm concerned i might destroy the ripper in the hardpan.
Thanks...
2,587
A trencher or rock saw would be best for the trenching.
A skid steer with hydraulic driven auger would be best for the post holes.
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
572
578
Lake Almanor, Ca
Welp, I have similar material and interlocked rocks from volcanic activity…with about the same set up as you OP. I put in about 3000’ of trench by just going slow and working my rig hard. The good news is that I have several large rock retaining walls!
selftot
L3400
Aug 6, 2025
46
Vancouver Island
Makes sense. As usual, i'm looking for the magical implement that is inexpensive and does everything well - LOL.
I dont have enough need/budget for a hydraulic auger. It might work with specialized bit ? I tried a pto auger with a standard bit and it was useless.
I'll probably go slow like @Tarmy and get a pile of rocks. And wide holes that have to be packed.
Still wondering if the ripper might help. For a few hundred bucks it'll still be slow but maybe not as slow... It would be useful on stumps i need to deal with.
Tarmy
Nov 17, 2009
572
578
Lake Almanor, Ca
‘You wanna do something to your rig that will REALY help is add a hydraulic thumb. That thing is the most used and best implement for my situation…and likely yours too. Makes the trench work and stacking walls way easier.
selftot
L3400
Aug 6, 2025
46
Vancouver Island
Thanks - I've had a mechanical thumb for years.
I've been doing some research on going hydraulic but not up to speed yet.
4,608
Our cottage has a similar “rock problem”…….No shortage of rocks. Some the size of Volkswagen's…..(The ICE ones, not the EV’s ;))
My BXepaned ripper tooth works very well though.
I can break just about anything if you give me the chance, but I would think that the BX Ripper tooth would be an asset for that job.
@Tarmy Love that hydraulic thumb!!!!(y)(y)
