l47 in limp mode, no codes.
Vlach7
L47 305DT JD500C
Dec 16, 2021
447
321
Frazier Park Ca
Where would be the best place to purchase the WSM for my tractor? 800hrs, recently cleared a code for when the RPM drops to low, #P0336. It has now no foot throttle response. I believe this would be considered "Limp Mode".
OntheRidge
Nov 1, 2020
485
574
Send me a pm with your email, I will attempt to send you the link for the wsm. Thanks to NIW for that!
OntheRidge
Nov 1, 2020
485
574
Sent to your email, hope it came through ok.
Vlach7
L47 305DT JD500C
Dec 16, 2021
447
321
Frazier Park Ca
Check your air filter
Thank you. This was a sudden onset; I clean my air filter all the time and for the most part only tractor after a rain. after I study the WSM I will let you all know what fixes it, hopefully not a trip to the dealer for an ECU reset.o_O
Vlach7
L47 305DT JD500C
Dec 16, 2021
447
321
Frazier Park Ca
Merry Christmas to all, I am blessed, went back out to try the manual or hand throttle and not the foot throttle. Every single thing seems normal now hopefully it doesn’t come back, thank you all.
Vlach7
L47 305DT JD500C
Dec 16, 2021
447
321
Frazier Park Ca
Not sure, couple weeks ago I had that P0336 code come up about lugging it or engine going to slow RPM and I cleared it the same day I cleared it. I changed the oil in my front drivetrain and put a new hydraulic filter on, then two weeks later which was a couple days ago. It would not rev with the footpedal above 800 RPMs and I thought that would be bad when it’s time to regenerate because I won’t be able to get it to needed RPM, would run in low medium or high at 800 RPM, got the WSM and couldn’t really figure anything out but figured that I could use the manual accelerator that increases the RPMs and I did that today and it raise the RPMs with that and then also the foot pedal so I am not sure if it will come back but it appears fix for now.
OntheRidge
Nov 1, 2020
485
574
I am a little confused, there is no foot pedal accelerator. The foot pedal is the HST control. The only time it increases rpm is if you have auto throttle turned on, on the control panel. Is it possible that was on previously, and got turned off somehow?
Vlach7
L47 305DT JD500C
Dec 16, 2021
447
321
Frazier Park Ca
I’ve only had it five years and maybe I did have a senior moment but it’s working now and I will be more aware of that auto throttle, yes, the HST pedal was not working
Vlach7
L47 305DT JD500C
Dec 16, 2021
447
321
Frazier Park Ca
Thanks, you were correct, my auto throttle was off.
OntheRidge
Nov 1, 2020
485
574
Glad you figured it out, and it was something simple!
