L5030 w/V2403....to rebuild engine or not rebuild engine.....
psu927
L5030 tractor
Dec 21, 2025
Felton, Pa
L5030 owners... I recently obtained a 5030c-HST model with 2200 hrs, it was overheated and had a blown headgasket and cracked head. I replaced both. The 2 center cylinders had some scoring. I hate to even call it scoring, because I couldn't feel it with a fingernail but it was definitly wear at least through the oem cross hatching.
I put it back together with new head and got it running today. It starts and runs fantastic, (25 degrees here today) however it has a fair amount of blow by. Here is my first question,, for those that have this model, how well does your tractor hold speed on a relatively steep incline in high gear? I am trying to get an idea if I am down on power or not. I have a relatively steep driveway, and was noticably lugging the engine in high gear going up. I suspect this is normal but I am looking for comparison. Medium gear doesn't slow at all. Also how much blow-by do you have? (V2403 owners only). Some engines inherently have a fair amount.
My conundrum.... my 4wd propeller shaft is also leaking, as well as injection pump has a slight leak. (delivery valves) Since I need to split the tractor to replace the shaft seal, I am wondering if I should tear the engine down and do a rebuild, or fix the seal and run it as-is. Like I said, it starts and runs great, no smoke out the exhause either. Thats why I ask about the power. I can deal with the blow-by if I am not down on power. For reference, if I plug the crankcase vent with my finger and set the oil fill cap in place (not pressed the whole way down) it blows the cap off. So it's significant. Tractor cranks smooth though.
Right now as it sits I am around $10,000 into the tractor total. It's in great condition with a cab and loader so I'm assuming value is upwards of 20-25k. I fix the leaks and run as-is or do a full rebuild? I will do the rebuild myself except for the machine work.
10,005
It's normal for them to not be able to climb steep slopes in high.
Don't play guessing games, just do a compression test, that will answer your rebuild question.
psu927
L5030 tractor
Dec 21, 2025
Felton, Pa
I may, even if it shows negligible or somewhat poor results, the tractor runs so good I guess I have to weight he cost vs reward.
4,634
If my $10K tractor, that was valued at $20K ran good, I don't think I would mess with it, until it became problematic.
For a ’not so direct” comparison, my 2501 “lives in Medium” and has only seen “high” once or twice.
Hell, I might just keep adding (whatever) fluid it needs, especially if it’s only “once in a while”, and skip the seal replacment.
Sort of a “run it, like you brung it” thing.
But there are those of us that like to “fix things”.
Sort of depends on your personality I suppose.
Thats my .02…good luck (y) (y)
hedgerow
441
426
Malcolm NE
If it was me I would have pulled it apart while I had the head off and fixed the cylinders, shaft and pump then . Now that its back together I would just run it. How bad is the shaft and pump leaking? How many hours a year are you going to put on it?
psu927
L5030 tractor
Dec 21, 2025
Felton, Pa
I debate it. I couldn't do a compression test before the repair due to the head gasket issue, and since I couldn't "feel" any scoring on the cylinder wall I put it together. In hindsight I should have at least pulled the pan and pistons and checked the rings and did a hone-job. Still might do that. I can pull the head in an hour.
I have parts ordered to seal the pump, gonna at least take care of that.
yearly usage will be low. probably less than 50 hrs a year. I have a skid steer that does my heavy lifting, this will be mainly a snow removal and food plot machine.
hedgerow
441
426
Malcolm NE
If I was only going to use it 50 hrs a year I wouldn't worry about the engine. Sounds like it starts good and runs good I would just use it.
Randy1
Kubota L5030 HST
Feb 2, 2016
Colora, Md.
I have a 2007 L5030 HST that had 1,200 hrs. on it when purchased from local farmer. Mainly used to rake hay and lift bales. It has never had the power you would expect a 50HP to have as the HST seems to drag it down quickly on hills and whines a good bit until selecting medium range and increasing rpm. I don't use it to pull loaded trailers due to the lack of power. Always thought there was an issue with the HST because it whines under load but haven't really looked into it and its now showing 1,800 hrs. Had a JD 30hp. with HST and it seemed to pull better than the kubota. Wish it had more power but personally thinks it's the nature of the beast.
jyoutz
Jan 14, 2019
3,504
2,591
Edgewood, New Mexico
High range is meant for road travel, not pulling hills or towing trailers.
