L345 with 1720 loader issues
Shadetree55
L345dt, L1720 FEL
Nov 5, 2025
Oklahoma
My loader quit on me the other night. No visible damage to the pump. Was trying to lift a heavy load and when I backed up to get a different angle the loader wiuldnt raise without really revving up the throttle. Then it was jerky and felt like it was on a bind. Now the loader won’t even act like it’s going to lift. Any possible suggestions what I should look at? Thanks
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
706
327
Herald Calif.
Is the pump turning? Common problem is the key on the pump will share.
3,069
I suggest you start a new thread or ask a moderator to split this off into a new thread. You will probably get more responses from a new thread.
But you need to provide some more information or pictures about how it is powered. Is there a pump on the front of the engine or does it use the hydraulic pump on the engine?
If there are any quick disconnects on the FEL connections take them off, inspect them for damage and reattach them to the tractor. Often they can come part disconnected (by bumping into something) and cause flow problems in the system.
Shadetree55
L345dt, L1720 FEL
Nov 5, 2025
Oklahoma
But you need to prove some more information or pictures about how it is powered. Is there a pump on the front of the engine or does it use the hydraulic pump on the engine?
Thanks! How do I get the moderator to do that? It’s an external pump. No quick connects. But hydraulic lines are very crispy. I’ll take some pics when I get off work today. Thank you
Shadetree55
L345dt, L1720 FEL
Nov 5, 2025
Oklahoma
External pump on the front of the engine
3,069
There are several moderators and you can see if/when they are on line on the forum main page. You can start a conversation with them and ask them or just ask them here.
@whitetiger, @North Idaho Wolfman are the most active moderators. By putting the @ symbol before the user name you send them an alert that shows up at the top right side (a number on the bell symbol). You should have gotten an alert since I replied to your post.
Since you have the external pump system, I have to assume that something there has failed.
Have you checked the fluid level in the FEL sump (which is probably not the tractor transmission) but in the FEL itself (possibly one of the towers)?
You need to verify that the shaft is actually turning and putting power into the pump. A visual inspection at the front of the tractor will show if the shaft is actually turning if you can see it. You might need someone to operate the FEL valve to see if the shaft stops rotating under load. Another way to test the pump is to add a pressure gauge into the line and activate the valve but since you don’t have disconnects that is a little bit more difficult.
I would figure out which side of the pump is the output line (goes to the valve) and disconnect it. Either end would work but you may want to disconnect it at the valve so you can put it in a bucket and see it when you start the tractor. Fluid should come out at a good flow rate but not too much pressure when the tractor is cranked or running at idle. You could then add a tee into that line and add a pressure gauge if there is flow.
Shadetree55
L345dt, L1720 FEL
Nov 5, 2025
Oklahoma
Thanks for your help! I did check the fluid level in the external tank. The dipstick is gone but it’s a little over half full. I did add a little to bring it up but didn’t add much. From what I researched it should take 5-6 gallons ? I had thought about taking the pressure side off to the valve but wasn’t sure about it. It should flow like you said at idle and if the valve is opened it should shoot out at a high pressure if pump is working right? Sorry I am just learning and know very very little about hydraulics so far. There is a filter on the return side of the external system but on the inlet side it’s just a 1” hose straight from the tank to the pump. Don’t see anywhere there could be a filter or a screen. I greatly appreciate your help!
3,069
There will NOT be high pressure out of the pump outlet until a valve diverts it to a work port.
Think of it like a garden hose. There is little pressure out until something starts to restrict the flow out of the end. If you capped the end of the hose, flow would stop and pressure would build up inside the hose to the full water pressure.
So the FEL valve diverts the flow into one end of the cylinder (closed space) and then the pump keeps pumping fluid into the space, it increases the pressure in the cylinder and then provides enough pressure on the cylinder piston surface to move the load.
7,221
Tske the hose off the P port on the valve and stick it in the hydraulic filler on the loader. Start tractor and check for flow.
If you have flow reconnect that hose and connect a pressure gsuge to one of the four cylinder ports. Start tractor and operate the control lever to direct flow to the gauge. Hold lever in that position and read pressure.
Shadetree55
L345dt, L1720 FEL
Nov 5, 2025
Oklahoma
Thanks! Pulled the pump off this morning and it was a sheared key way. I think the shaft attaching the pump to the tractor is a home made job. It’s got a u joint with an end for a straight shaft with a key way going onto a splined shaft with a set screw holding it. Any ideas where I can find a correct piece for it? Thanks for everyone’s help with this!
Shadetree55
L345dt, L1720 FEL
Nov 5, 2025
Oklahoma
Thanks. Ended up being a sheared key way.
7,221
Is the pump shaft splined or keyed?
7,221
Shadetree55
L345dt, L1720 FEL
Nov 5, 2025
Oklahoma
These work greaf.
Awesome thanks! What can I use to attach the other end to the shaft on the tractor? I’ll attach pictures of the shaft I have now in a couple of days. I have it soaking in oil to get the set screws freed up.
3,069
I can’t be 100% sure what you have since there were some variations on the way the front PTO was done. I am pretty sure your tractor has a splined end of the crank shaft that passes through the front pulley. Then there were shafts that were splined internally to match that extension. I believe they were locked on with at least one set screw. Others had a spline internally but also bolted to the pulley.
The other end of the shaft (nearer the front end) was usually cylindrical with a keyway. Then a flexible coupling half was installed on the tractor shaft and pump (or whatever) shaft. Most of the couplings were chain couplings (see link below):
Since your key sheared (or you say it was the shaft?) there was something that required too much torque or that area was fatigued and failed.
Have you checked that the pump is free to spin? You should be able to turn it by hand if you have it disconnected from the tractor. Check that out and see if there is any wobble on the pump shaft.
Please clarify what shaft and/or keyway is sheared, maybe with a picture!
On edit: sorry for some duplication of information but I typed slow!
Shadetree55
L345dt, L1720 FEL
Nov 5, 2025
Oklahoma
Yes the pump is good. Spins free and no play in it. The crankshaft off the tractor is splined. So the set up I have now is soaking in oil to free up set screws. But it’s a key way on the pump that has a shaft on the end. That shaft is going into a small u joint and that u joint attaches to the crankshaft. I’ll take pictures of the set up in a couple of days when I get it out of the oil it’s in. Thanks!
7,221
I am not clear on what you are replacing. You are not going to match the crankshaft spline without a lot of searching if at all.
