FEL Control Valve question
frysl
L3301 LA525 FEL & FDR1672 6' Finish Mower
Jun 13, 2016
96
17
Sumner County, TN
I’m starting to have intermittent issues with the control valve for my 525 loader. Moving the arms down from an elevated sometimes now wants to continue downward travel when the lever is moved back to the nutural position. It also now feels stiff when moving the lever up and down.
can the valve body be rebuilt?
7,103
The answer is no and you are jumping way ahead. Start by checking operation of the joystick linkages. Kubota joysticks are well known for failures.
frysl
Jun 13, 2016
96
17
Sumner County, TN
I’ve already checked that. Im also wondering if weather might be an issue. Although the tractor had been warmed up adequately, the weather here was below freezing while this was occurring.
7,103
Have you verified the boom spool is actually returning to neutral? Its the only thing blocking return flow from the cylinders.
