B7510 loader removal
Maverick
B7510HST
Jul 28, 2012
10
Katepwa Lake,SK, Canada
I have a B7510 that is currently DO A . Safety switch issue I can't track down, therefore needs to go to the shop.
What is the easiet way to remove the loader if I have no.power ?
Thanks in advance.
2,609
You should be able to jack up the bucket to raise the FEL off the ground, then block the cylinders to hold it up. If you are pulling it forward then run the strap under the bucket and the bucket should raise off the ground as you tension the strap.
Some have mentioned they can use the ROPS with straps to hold the bucket up.
10,031
You should be able to jack up the bucket to raise the FEL off the ground, the block the cylinders to hold it up. If you are pulling it forward then run the strap under the bucket and the bucket should raise off the ground as you tension the strap.
I think he wants to remove the loader from the tractor.
10,031
Thanks in advance.
What is the tractor doing or not doing?
If it's not cranking there is a workaround to get it started.
If it's cranking and not starting then you have more than a safety switch issue.
2,609
I think he just wants to get the tractor to the dealership and thinks removing the loader would be the easiest way to get it onto a trailer or back to his drive/barn. But maybe he does just want to remove it but I have no idea how to do that without the tractor running. Perhaps you can give him a method??
10,031
I just get them running, it's easier than messing with a dead tractor and loader. :ROFLMAO: :ROFLMAO: :ROFLMAO:
Otherwise just jack them up and block them. ;)
Maverick
B7510HST
Jul 28, 2012
10
Not cranking. I can hear solenoid s clicking.
I'm open to get it running.
I had to bypass the safety switch for the H ST pedal.
Worked for A few days. Now nothing.
10,031
Turn the key on, put the range lever in neutral, go to the starter and jump the main battery cable to the little terminal on the end of the starter solenoid.
It should crank and start.
JimDeL
BX2380; 54" MMM; FEL w Pirahna bar; Ballast Box; BXpanded skid plate.
Aug 31, 2022
414
468
NE Ohio
No luck. It just clicks . Starter does not engage.
1. Possible bad ground from battery to chassis. Make sure it's clean and tight.
2. Possible weak battery. charge, or maybe replace.
3. Possible failed starter motor. Least likely of the three, but still possible.
Also, check the safety switches. PTO disengaged, HST pedal in neutral position, Range lever to neutral, and seat switch operating. Fuses good. Should at least try to crank.
Hugo Habicht
G1900
Jun 24, 2024
1,175
1,702
Ireland
If it is the starter solenoid clicking then the solenoid contacts are worn or the starter brushes are worn.
10,031
Either dead battery or dead starter.
3,337
Turn the headlights on before you try to start it. Do they light?
Observe the headlights when you try to start it. Do they stay on or do they go out?
Report back…😊
