Bush hog blade blues UPDATED WITH PICTURES
texican
L3000F, FEL
Oct 12, 2023
105
22
East Texas
Thanks for any advice.
First tractor/brush cutter, had it about two years. Done a good bit of maintenance on tractor now I thought it was time to get the cutter some love. Its a 93 M&W (absorbed by Rhino if what I read is accurate). So the blades, which I assume to be the originals had chunks missing and were rounded off and dull. I bought new blades, ran the existing nuts all the way down with my 2 gallon compressor that is used for airing up tires and pool toys.
Took the tractor to the farm (rookie move not engaging the new blades at home where all my tools are just to see how she ran) , an hour away, engaged the blades and the cutter shook like you wouldn't believe, well maybe this has happened to you and you would actually believe. Looked up under the cutter and tried to spin the blades and they wouldn't move. The were stuck in whatever position they were in when I ran the nut all the way down with my 4gallon 200 psi job site compressor from HF, would not rotate at all.
Got on the forum and the consensus was I shouldn't have cheaped out and should have bought the new bolts and washers to go with new blades. (I agree, that was super cheap not to). A cpl of guys told me the shoulder of the bolt would/should/might be different than the original ones I reused. Even if not, I def should replace the bolts that have been in the cutter since 1993. I was/am in totally agreement.
I got the bolts/washers and put them on. Now, using same compressor, I can only get them about 60% -65% on. Everything is the same but the nuts/washers. I went too hard on that small compressor and could smell it. I had condensation coming out of the wrench end of the hose. Wont turn anutha furtha. The blades have a lot of up and down play due to the bolt still having plenty to go.
This weekend, I took 1/2 ratchet and an extension and and had my wife hold pressure down on it while I tried to get it turn with an 8ft cheater pipe..I thought either the extension, the chinese impact 1 5/16 impact socket or my granddad's 1960s Craftsman ratchet was going to break. Tried it several times just up to the breaking point..nothing. I even soaked the nuts in penetrant for about 5-6 hours while doing some other work.
So, was I able to run the original nuts down on the new blades with my small compressor because they threads were worn down or something. Visually, I see no difference.
FYI.. the new and old bolts look identical in every way. I've tried to find the slightest difference to explain this and I see no differences at all.
What is my next move, to take it into a tractor shop or mechanic shop and see if thet can run it down with a much bigger compressor?
Thanks for any direction on this. IMG_3789.jpg IMG_3793.jpg IMG_3819.jpg IMG_3826.jpg IMG_3822.png nbob.png newboltoldblade.png odob.png IMG_6752.jpg boltmeausrements.jpg
SDT
Apr 15, 2018
3,642
1,372
Difficult or impossible to diagnose from available information.
Photos of both new and old bolts, blades and assembly might help.
Are new blades same thickness as old blades?
texican
L3000F, FEL
Oct 12, 2023
105
22
East Texas
Thanks. Youre right. Let me get some pics and measurements and Ill update.
2,939
I am not sure you really have a problem IF the bolts and the blades are from the original manufacturer (or match the original).
This is a picture of a typical blade bolt. More information is below the picture.
The bolt should have a medium shoulder diameter that fits the hole in the blade carrier (Shown in blue above). The blade carrier thickness should match the medium shoulder length approximately but I recall the shoulder length will be a little shorter than the blade carrier. Then another larger shoulder (shown in red) on the bolt should fit the hole in the blade but not as tightly as the shoulder in the blade carrier. Again the blade thickness and shoulder length will be approximately the same length. Then the threads for the nut are the smallest diameter. There is usually a washer involved between the nut and blade. The nut tightens onto the white shoulder of the bolt but does NOT put compression on the blade. The blade is free to rotate 360 degrees on the blade bolt!
The blade is installed onto the bolt, the bolt and blade are then installed (from below) through the blade carrier and then the washer is installed and nut started. Notice that there is some method on the blade bolt that stops any rotation of the bolt (green tab in above example). That tab must be aligned with the slot in the blade carrier. Then the nut is tightened to a specific torque value. The tension of the bolt is not against the large shoulder (yellow shoulder above), but the tension is from the white shoulder to the bottom of the nut. The blade is not compressed at all and should be free to rotate 360 degrees.
Since you are working beneath the shredder, that can trap and crush you, you must use some wooden cribbing to support the shredder! Do not rely on the tractor hydraulic system to hold it up. Then the blade is also pretty heavy so you may need a helper to install the washer and nut from above- but they should be careful not to push on the shredder. I used some blocks to hold it up and then installed the washer and nut but a helper is much better.
Old Machinist
May 27, 2024
645
758
NE FL
Sounds like the new bolts are incorrect thread or you cross threaded them.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,897
2,312
Western MT
I would try to find a manual for a brush cutter from Rhino or email/call them for help.
I don't use my brush cutter very much, so I've never changed/tightened blades on it. On my pull behind Swisher, it's possible to tighten the bolts too much. Going from memory, but I think it was tighten and then back off some amount (maybe 1/2 turn) or something like that. If they are too tight, they won't turn.
texican
L3000F, FEL
Oct 12, 2023
105
22
East Texas
texican
L3000F, FEL
Oct 12, 2023
105
22
East Texas
def not crossed..threaded them on like butter for a good ways by hand...made sure of that. YOu may be right about bolts..well find out when I get some data on my end. thanks for reply.
texican
L3000F, FEL
Oct 12, 2023
105
22
East Texas
This information is GOLD!! thanks for taking the time time withe the pics and the colors codes!!
ive read it three times...printing it out now to take home and read again and going to look for my old bolts and pull the tape on them. thanks a million for sharing you time on this...
texican
L3000F, FEL
Oct 12, 2023
105
22
East Texas
its hard for me to say I tightened them too much on the first time with old nuts but buddy..they were not moving..so I guess I did but it may be due to the wrong bolt...gotta drive an hour to where to I keep my tractor and get the data on them.
2,939
One other comment on the bolts and the amount of torque = it is a whole bunch of Foot-pounds!
I used a 4x torque multiplier and it still kinda hurt my skinny arms to reach the required torque! There was not a lot of turning movement after it was tightened up by a 18 inch ratchet to reach the final torque.
texican
L3000F, FEL
Oct 12, 2023
105
22
East Texas
Hey, man I uploaded a ton of pics of everything I could think of that would help. I would be appreciative if you could check it out and tell me what you think it could be. thanks
texican
L3000F, FEL
Oct 12, 2023
105
22
East Texas
SDT
Apr 15, 2018
3,642
1,372
Initially, new blades not the same as old blades. New blades have significantly more drop.
Did you remove the paint on the new blades before installation? New blades with new bolts will have little clearance and blades must pivot freely.
Nuts must bottom out on bolt sholders or blades can come off in use. Not something one can do with a 2 or 4 gallon compressor and pneumatic impact wrench. Need large, two-stage compressor and around 150 psi or big electric impact wrench.
10,697
The new bolts and new blade look fine to me.
They are not supposed to be tight, the blades are supposed to swing on the bolt.
Am I missing something?
2,939
Extracted new pictures from old post to get them close to their correct time position. Pictures below were added to the original post from 12/15/2025 on 1/9/2026 (today).
View attachment 168097 View attachment 168098 View attachment 168099 View attachment 168100 View attachment 168101 View attachment 168102 View attachment 168103 View attachment 168104 View attachment 168105 View attachment 168106
The new blades look different than the old blades. Did you buy the new blades to match the old parts or just get a “blade that should fit some mower”?
I had to find mine (blade number) from the mower manufacturer and then buy it through one of their vendors since they don’t sell the blades directly from the manufacturer.
They look correct when you team the new bolt and new blade so that may work. See if the bolt is getting tight on the white shoulder shown above and that there is still some thread down in the blade holder bolt. I would suggest you just put the new bolt in and leave the blade off to look at it. If you have someone else to look at the other side (top or bottom) it would make that easier to do.
If they get tight and the blades rotate on the bolts 360 degrees without hitting anything, I think you are okay. As long as the blades are up within the mower shell when you put a board across the front runners on the mower that is a must.
5,123
texican
L3000F, FEL
Oct 12, 2023
105
22
East Texas
My little compressor is not going to run it down another thread. So I am wondering if everything is good and I need to just seek more torque...odd since I ran the old ones down almost too easy.
Is it normal that if I hand rotate the blades around so that the ends are facing each other that they can touch? Does centrifugal force keep them from hitting when the PTO is engaged? I never tested this on old blades, and they are a good bit shorter but Im sure they, too, have the ability to touch if you turn them towards each other. Can you tell more about using a board on the front runners? This is my first blade change (boy has it put me behind, too).
Yeah, they look a lot different and a lot heavier. With the manufacturer (M&W) now defunct, I researched and I THINK, they were absorbed by Rhino, so I called a regional Rhino dealer, gave them the serial of the cutter and this is what they ordered for me. What I still don't understand, is how I was able to run the nut all the way down on the new blade with old hardware using a 2 gallon compressor at 90PSI, so tight that the blades would not rotate. And now that I am using new hardware I cant get the nut any more than 50-60% down and the blade flops up and down a lot vertically...(I tried to upload the video but it wouldn't let me)
texican
L3000F, FEL
Oct 12, 2023
105
22
East Texas
My outer blades swing pretty freely on my LP Rotary cutter.
Now if you need more torque, thats a different matter.
I recently was trying to torque a "crush sleeve" on my rear axle and had to break down and buy one of these “Torque Multipliers"
It worked great.
https://www.amazon.com/dp/B0DGYSFR3R?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1
Morning, so the blade movement I am dealing with is up and down because I can only get the bolt ran about halfway down. I think the multiplier may wind up in my cart asap. First, I'm trying to figure out if my issue is lack of torque since I was able to run the old nut on the new blade all the way down to the point they wouldn't rotate. Now, with new bolt I cant even get it close to tight. Wish it would let me send video. What makes it worse is my tractor is hour and half a way so I'm hoping to get a good idea what it is to keep from making a bunch of trips back and forth trying stuff. Its an odd one for sure.
