Seized Quick Attach Pin
GRickG
M4900, SVL75-2
Dec 12, 2025
3Dogs0Cats@1
My 2022 SVL 75-2 Skid Steer has a seized left attachment Quick Attach pin. Any suggestions? The pin in the down/locked position with the bucket on.
My three failures: a 1500W rotary hammer, Boom pushing down against a socket on top of a bottle jack, 4 pound hammer striking an iron bar. Each with Kroil penetrating oil from the top. Now I parked the SVL on a hill/ledge so I could lower the bucket enough to seep Kroil down the slanted pin from the lower end. I will re-apply the hammer after a couple days of seeping Kroil.
Can I torch heat the pin socket near the grease fitting?
4,621
I don’t see that you really have a choice but to use the old “flame wrench” at this point.
You seem to have tried everything that you can/should.
How long has “it” been on? Seems awfully strange that corrosion could/might be the problem, but I suppose that anything is possible.
Is it possible that something got bent?
Got pics?
BAP
Dec 31, 2012
3,087
1,223
Must be you haven’t been using the grease fitting?
John T
2017 BX23S
May 5, 2017
1,167
697
under a rock
I had a heck of a time with my New Holland skid quick connects when I got it.
It was gummed up with hard grease/dirt and horse sh*t ... rusted a good bit to boot.
I soaked it with Kroil and worked it for a couple days with a long cheater bar on the handle.
never resorted to a torch but once I got it moving I took it all apart and cleaned it all up new zerks etc.
take your time, It will work loose... Unless you got a broken part inside...
