The time had come
7,012
At 475 hours the original Titan SS fronts on my L3901 were done. Those tires have been superceded by Titan SS II which retail for $175. I decided to give these EuroGrip SS tires a try. Black Friday sale price was half off at $75 each!! Hard to go wrong at that price.
Reactions: 9 users
Hugo Habicht
G1900
Jun 24, 2024
1,533
2,199
Ireland
Hello Dan,
what is the situation with changing only front tyres in four wheel drive? The diameter is a good few percent bigger now than before. Does that not cause any problems? Although on a hard surface it is two wheel drive anyway, I suppose.
Kind regards,
Hugo
7,012
Hello Dan,
Kind regards,
Hugo
It causes no problems. The tires are sized by the OEM to match the lead on the tractor when new As the tires wear the lead is reduced making it closer to neutral.
In my case the tractor is operated full time in 4WD even on pavement which simply causes the fronts to wear faster
6,276
Was wondering how you managed to wear the fronts out in 475 hours. 4WD on pavement explains it assuming a good percentage of those hours are on pavement. 👍
You have any concerns about stress on the driveline routinely running 4WD on pavement?
7,012
Zero concerns. All it does is modestly increase the load on the front differential gears I am sure thats well within the operational design limits of the gearbox. If its not the engineers are not doing their job.
Da
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,912
2,324
Western MT
I only have about half what you have. What do you think we're doing to wear the fronts that much. Mine look about new still.
Maybe it's the temperature difference I don't use it much when it is really hot.
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
128
127
Lakes Region, NH
Okay, I'll be the one that asks the question. Why is the tractor operated full time in 4WD even on pavement?
7,012
Because 4WD is essential when operating on grass. In normal operation its constantly on and off and switching back and forth is impractical.
bobnic
Mar 7, 2025
128
127
Lakes Region, NH
That begs the question as to why 4WD is essential when operating on grass. I almost never use 4WD on grass since it tends to tear it up when turning. Perhaps you have steep hills with grass that makes it necessary.
bobnic
Mar 7, 2025
128
127
Lakes Region, NH
I would not have needed to ask and answer my own question had your original statement that 4WD is essential when operating on grass (which is generally not true) been more specific about operating on steep grass. Even so you must turn at some point and do some damage, but that's just the price you pay for the traction where you need it.
7,012
This whole exchange could have been avoided had you not felt compelled to question my decision making.
My life is more important to me than some skid marks in the lawn and the cost of some tires. In the last 35 years I have had more than one runaway event. If you have never experienced one you dont know what you are missing.
6,276
First pic in post 9, right side of driveway: looks like a great place for some impromptu tractor sledding in 2WD.
Ridger
L3940 HST
Nov 26, 2014
160
North LA
The EuroGrip tires look great and also a great price. They should last you a long time. I replaced all four of mine a couple of months ago. I went back with Titan Trac Loader II. The originals still had good tread, but were cracking and getting dry rotted.
BTW....your property looks nice. The rock fence is cool. I live in the deep south....not sure I could take your winters.
7,012
And what you cant see is there is a vertical cliff once you get to the bottom o_O
In spots that is steep enough you cant climb it even in 4WD. I mow it top to bottom and circle back around on the pavement after each pass.. Tedious but doable and looks good when mowed up.
There are plenty more places just like that and some worse.
