Should I upgrade from LX2610 to 4020?
greenlifevt
Kubota LX2610, HLA SP180072 Snow Pusher, Land Pride SB1064 Snowblower
Dec 6, 2025
Bolton Valley, Vermont
For the past two winters I've been using an LX2610 with an HLA 180072 snow pusher on the front and a 64" snowblower on the rear to plow a 500 ft road and small condo association parking lot at a ski resort in the Vermont mountains that get's an insane amount of annual snow. 8"-16" dumps in less than 12 hours are pretty common. It's pretty much done what I've asked of it, but struggles when the pusher is loaded with snow and nearly stalls on an incline without dumping some of the snow weight. This was my first tractor and a great learning experience, but after two winters, it feels slow and tedious moving snow with it. The small footprint of the LX let's me backdrag snow out of a single parking spot when cars are on both sides and turn around in some tight spots surrounded by parked cars even with the snowblower hanging off the back, where I'm concerned that wouldn't be possible with a larger tractor. I haven't really felt like the snowblower was underpowered... it does just fine blowing snowbanks 30+ feet back when needed. A larger snowblower would be nice, but also couldn't fit into the tight spots I need it to.
My question is: Will the higher horsepower of the 4020 increase the "pushing strength" so pushing a heavy load up an incline won't stall the tractor, or is it only good for more PTO strength? I asked my local Kubota dealer this and he 'yes' and is trying to sell me a 4020, but I'm not sure he isn't just trying to make a sale. The 4020 is pretty sweet and doesn't have that damn hydraulic whine, but if it isn't going to increase my snow pushing strength and speed, there's no sense upgrading to it. Thanks.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,771
2,212
Western MT
Yes, more HP will help it go up hills better. If you have the money, I think it's a great upgrade. From what I've seen the 20 is quite a bit better than the 10 series.
This might be obvious, but do make sure you get the tire type you want.
BruceMc
BX25D LX2620
Sep 27, 2014
34
60
Fairbanks, AK
When you say 'stall', do you mean the engine stalls? Or you lose traction? I've got an LX2620 with the 72" pusher and while I'll sometimes lose traction, it's never actually stalled. Just loses forward momentum. More horsepower wouldn't have made any difference other than spinning the tires easier.
greenlifevt
Dec 6, 2025
When you say 'stall', do you mean the engine stalls? Or you lose traction? I've got an LX2620 with the 72" pusher and while I'll sometimes lose traction, It's never actually stalled. Just loses forward momentum.
I mean the engine stalls pushing snow uphill. I have studded tire chains all around. Traction isn't the problem.
greenlifevt
Dec 6, 2025
Good point about the tires. Right now I've got excellent condition R14s, loaded rears, with studded tires chains and we're on a mostly unmaintained dirt road. The road and all of the parking spots are being paved summer 2026. I can't run studded tire chains on brand-new asphalt, even if there is a layer of ice at some point during the winter season. Iknow I need to reconsider and research alternativce traction options for our situation.
#40Fan
470
322
Instead of pushing harder on the HST pedal, have you tried letting up a little?
PaulL
2,675
1,667
NZ
What gear are you in when it stalls? Low ratio would/should give more push. Usually these smaller Kubotas will spin their wheels long before they stall - they're normally traction limited.
More HP should let you push faster when you're in a situation where you have enough traction.
More weight would/should mean more traction.
If you can't run chains and studs soon, then you should look closely at what you buy. You may go from being HP limited to being traction limited. Is there something with rubber tracks you can buy that would do the job - a small skid steer perhaps (although skid steers aren't exactly easy on asphalt).
BAP
Dec 31, 2012
3,087
1,223
Have you considered using a front mounted snowblower and blowing the snow instead of trying to push it? Then put a rear mounted blade to pull the snow out of the tight spaces? If new pavement is going to be an issue, front mounted snow blower will take less traction than a snow pusher will.
SDT
multiple and various
Apr 15, 2018
3,426
1,199
SE, IN
Yes, the significantly increased HP of the LX4020 will increase both PTO and tractive power.
That said, once you can no longer use tire chains (at least ice type chains) you will become traction limited. Without chains, there is little you can do about this in snow and ice. Might want to consider both front and rear blowers in your case. The added HP of the 4020 will be very helpful in this case.
FWIW, your 2610 will not be HP limited while pushing snow if in low range.
greenlifevt
Dec 6, 2025
Thanks. This is good to know. However, I do "feather" the pedal when it's struggling pushing snow uphill.. I don't just slam it down, but as I increase pressure on it, it approches a stall unless I dump some of the snow weight.
greenlifevt
Dec 6, 2025
It's in low gear. Medium or high it would stall much sooner.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,997
2,470
Near Lancaster, PA, USA
I'm usually a bigger is better than fan. However in this situation it sounds like you have a size suitable for the work / accessibility. My first thought would be to do an occasional "shove it off the side" and take another bite.
Next would be switch to an angled plow so the snow doesn't gather but slidesoff to the side. I can back drag with my blade. Witha lot of large snows you could run out of space to push it off the sides.
SDT
Apr 15, 2018
3,426
1,199
SE, IN
A HST pedal does not function like an automotive accelerator pedal.
Pushing down on an HST pedal reduces the effective gear ratio of the transmissioin reducing torque at the wheels.
If you are running out of power you need to increase throttle and/or apply less HST pedal.
PaulL
2,675
1,667
NZ
Pushing down on an HST pedal reduces the effective gear ratio of the transmissioin reducing torque.
This is the very non-obvious thing. And I feel like @SDT is correct, but perhaps not as clear as he could be.
The HST pedal is a gear stick, not a throttle. You press an HST to go faster, because it's changing up.
In one sense it works like a throttle - you go faster when you press it.
In another sense it's the opposite of a throttle. A throttle gives you more power when you press it. But a gear stick does the opposite - when you change up you have less push. To get more power, you change down - i.e. reduce how hard you're pressing the pedal.
GrumpyFarmer
4,650
Good day.
I am still not sure I understand the ‘stall’ that is mentioned or the HST setting you are in when it happens. If in the low setting and pushing snow it’s hard for me to image my B stalling out before it would ever break traction. If in high going up a hill sure I understand.
Maybe I missed it but what HsT gear ration are you in? I also wonder how deep is the snow you are pushing and when the box fills up are you pushing it off to the side?
either way, if I were to spend that much I would want a demo if not sure the capability for your task.
Id tell my dealer the situation and tell them you want to buy IF it will do your task. for me I’d ask the dealer for a demo…if they won’t bring one, ask if you can try on in the lot at dealer on the next snow storm.
SDT
Apr 15, 2018
3,426
1,199
SE, IN
Good day.
He's obviously using too much HST pedal.
ajschnitzelbank
Aug 24, 2021
268
669
Rensselaer County NY
Hah, I’ll start by assuming you know exactly what you’re doing…
I had a B2301 with snow pusher, R4s, four euro style chains, and a back blade. Now I have an L4701 with R1s, no chains, snow pusher, and back blade (eight foot wide).
I just plow my own property, less than you do. I boarder VT and get a fair amount of snow.
One thing I’ll say is although the L series is bigger, the turn radius is still very tight, so I don’t usually feel “too big”. Sometimes I do, but honestly really not that often.
Also, the added weight and R1s provide plenty of traction for my needs without chains.
I wonder if the dealer would let you borrow one for a day to try plowing and see if it’s like annoying how big it is, or it’s just awesome and you fall in love.
Good luck with your decision!
