Gear shift not staying
Weimar
27
N of Spokane, WA, USA
I had this in the shop, ALL summer, so went to get it back and was moving manure from near the house.
The rubber bootie broke, i thought I ordered the correct one, looks small.
Got the parts number from the forum.
Will not easily go into gear, help please...
pictures below.
Bee-Positive
Nov 16, 2022
779
778
Amsterdam, NY
That 40 year old boot looks pretty dry rotted. Probably got 10 years worth of dust, dirt, and water in there. Take it apart, clean it, lube it up.
2,903
Go to this website and type in your tractor model and you can see illustrated parts lists and find the correct part number. Sometimes they are specific model number and/or serial number specific.
10,686
Yes
I need to know the proper boot to replace it.
one step at time……
Give me the tractors serial number near where your left foot goes.
The boot that is on your tractor right now does not look like a B7100 boot, most likely aftermarket.
10,686
Sorry no, need the serial number, it will be stamped in the left side of the clutch housing. 1770276150891.png
5,093
Or, possibly, go to your local auto parts store and try to find an automotive CV boot that will fit.
Just an idea. 🤷‍♂️
SDT
Apr 15, 2018
3,635
1,359
pictures below.
Once you get the correct boot, turn it inside out and heat it up in hot water for easy installation.
