Things to look at when buying used BX?
Hockeyman70s
MA
Hey all, first post, looking at a 2017 BX25 with under 200 hours.
Paints pretty faded so probably been stored outside.
anything that tends to go wrong on these or that’s worth checking out before I buy?
thanks!
Spam Bot
Windows Computer
Aug 3, 2024
179
129
Austin, Minnesota/Key West FL
Check the condition of the rubber hydraulic hoses. Tractors stored outside in the weather have rubber hoses that deteriorate faster than those stored inside. Also, outside storage is known to take its toll on the instrument panel. Tire sidewalls tend to crack with age. My 2019 BX23S needs new tires, as they are showing weather checking, even though it is stored outside under cover. Tire rubber ages faster nowadays than it did 20 years ago. I am sure that others will have additional helpful hints. Keep in mind that if you are not mechanically inclined and have to pay someone else for repairs, a used tractor might not be a good bargain, since a new tractor comes with a warranty.
Bee-Positive
Nov 16, 2022
1,081
1,005
Amsterdam, NY
Welcome aboard Hockyman!!
I'd worry that regular maintenance hasn't been done. Oil and oil filter, hydraulic fluid and hydraulic fluid filter and gas filters should have been changed due to time - regardless of the hours on the meter. Look for grease around the loader and other point of lubrication. A greasy tractor is actually a well maintained tractor.
Also look for water in the diesel tank, sitting for that long is a good way to get condensate mixed with the fuel. The fuel filters have probably gone through a couple of freeze/thaw cycles too.
Hockeyman70s
MA
Hockeyman70s
MA
Thank you! I’ll be looking at it tomorrow- a lot of the pivot points are pretty greasy in the pics. Wouldn’t be worried about them leaking etc?
Thanks
PaulL
B2601, MX5200.
Jul 17, 2017
2,798
1,791
NZ
Excess grease means they were greased well. Pivots don't leak as such - whenever you grease them it pushes grease out the pivot. Those don't look like old grease so much though - they look like new grease. Perhaps he just greased it before selling it? It's always hard to tell, and I usually figure that most people are basically decent, so I'd focus on assessing the seller a bit. There are a lot of things people can cover up if they're dishonest, and any walk around you do won't see them. But if someone seems basically decent, and the walk around and test run seem good, then honestly it's hard to break a Kubota with 200 hours on it.
I bought a BX2350 (the bad plastic model) that had been heavily abused. Used by a commercial company, they clearly let the apprentice drive it. Every panel on it broken, the bits that said "don't step here" clearly stepped on. It was ugly, and the auction house weren't clear if it even ran. Bought it for a bargain, it started first time, and ran perfectly for 3 years before I upgraded. Kubotas are pretty tough, you'd be very unlucky for a 200 hour machine that's only 6 or so years old to have something major wrong with it.
Ping
BX2370-1
Dec 25, 2018
372
388
Troy, Ohio
OP, in addition to the above, be sure to check the plastic hydraulic cooling fan for missing/broken blades. I understand these are NO fun to replace!
Good Luck
Hockeyman70s
MA
thank you for the info! The original owner passed and it’s an estate that’s selling it so hard to get a read on the history, the seller says it was well maintained. They accepted a $10k offer so it seems like a good price.
xrocketengineer
Nov 14, 2020
911
877
Merritt Island, Florida
Together with checking the HST fan, check the CV joint boots at both end of the of the shaft connecting the engine to the HST. IMG_20221021_162015.jpg
Bee-Positive
Nov 16, 2022
1,081
1,005
Amsterdam, NY
At $10K you got an awesome deal even if you have to put a couple $$ into it.
Download the manual from kubotabooks
Change all the fluids and filters so you know it's all good.
Add anti-gel to the diesel, it's been pretty cold lately.
Edit - make sure you check / torque the lug nuts on all four tires.
Speed25
L2501(sold) - BX25D
Apr 23, 2024
340
526
NC
Was the BX25 model still being manufactured in 2017?
The tag says BX25 though the stickers say BX25D on later models, but I think the BX23S started in 2017, so maybe the 25 was unsold stock, sold in 2017?
SDT
Apr 15, 2018
3,686
1,409
When buying any used tractor one should always inspect the maintenance records. This is especially true of HST tractors as HST transmissions are not tolerant of improper or dirty oil.
PaulL
B2601, MX5200.
Jul 17, 2017
2,798
1,791
NZ
Or, if one gets a good deal from a deceased estate, and it's only got 200 hours on it, one should grab it and run laughing even if the guy who had the maintenance records is dead.
Mark_BX25D
Bx25D
Jul 19, 2020
2,112
1,614
You'll soon find out if the throttle lever is either slipping (common) or stuck.
PaulL
B2601, MX5200.
Jul 17, 2017
2,798
1,791
NZ
And......the rule around here is photos when you buy. :)
