Modify a stump bucket for better trenching?
Shawnba67
23
9
S.E. IN
So I am bored and thinking that I want to cut tire lanes to gravel in my favorite farm pasture paths. Im envisioning just two 18" wide tire tracks of gravel. I think i want to cut about 6" deep just get under the grass and make a good gravel depth.
Could I fab up a stump bucket with a ramp to attach to my front bucket? It would bolt or such to the bucket and the 6" of dirt will be ramped up into loader bucket? Set so the bucket cannot help dig just carry and limit depth. Or would that really strain the bucket?
If bucket would not work could the same plan, But on a ssqa plate work? Put on a Lil diverter to push the dirt to the side and scoop it later. Diy fab stumpbucket with mods?
Thanks I hope you put your boredom to better use than I do!
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,977
2,357
Western MT
I don't think it's a good idea.
Think about how you will maintain the gravel. In other words, next you will need a super narrow land plane, box blade, or rake.
Tim Horton
310
81
Lake Superior
Interesting.... My first thought envisioned a shallow, short, the width you want ..scoop.. that mounts to something like a FEL pallet fork back frame...
But then like said, maintaining this kind of ...path... may be a problem.. If it needs much or any maintaining at all.. ??
Give it a try, do a ..test.. area and report back.. Good luck..
7,680
You're going to create a project that will likely have a path for gravel that will not run parallel for your tires. If you really want some rock to drive on, hire a load of rock in small (6-8 ton) load have the driver block the center of the dump. You drive over the rock a few time and it won't above the grass to cause any problems.
Shawn T. W
Dec 9, 2024
821
1,497
SW Missouri Ozarks
What about a bottom plow, like is used to plow a field, on your 3pt ... Maybe pull it both ways would make it wide enough?
4,143
2,833
No problem
5,518
Do you have a backhoe?
That would be my choice if I was going to make “gravel tire tracks”.
But, (as posted above), how will you maintain them?
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,475
668
Richmond, Virginia
I second (or third) dumping gravel to make two 'piles' and drive over to compact it in. RoundUp the tracks in spring and more gravel. Hollowing out will hold water and may become mushy.
