** Help Needed ** BX2750D snowblower
RealMainer
BX2350
Dec 4, 2025
New England
Hi all:
This is my first post on this site but I've been using it to solve a variety of my tractor related issues over the last 10-12 years. I appreciate all of you for your knowledge, patience, and ability to explain various solutions.
I've got an unusual situation and I'm looking to bounce this off some like-minded folks. Last year I was snowblowing and sucked up a snow covered 3-4" branch and I must of tagged it just right and it snapped the shaft that feeds the impeller and gearbox.... literally sheered it in half like someone took a hacksaw to it. I pulled it into the garage and the following weekend I started breaking it all down, ordered parts, blah blah. As luck would have it this was the last time I needed the blower until just a few days ago when the northeast (Maine) saw it's first snowstorm of the season. All this is to say that I never had a chance to test the snowblower until yesterday since the rebuild.
Somethings funky now.. it won't throw snow more than 5 or 6' as opposed to the typical 10-12' it would have with this type of snow and it was bunching up Infront of the blower - almost like a plow. We got around 5" once it was all said and done so nothing crazy and certainly not something that would dictate bad performance.
First things first: Obviously checked shear pins - all seem fine and all intact. I thought I may of reversed the augers but those seem to be fine too, however, I'm not 100% other than I had my wife sit in the tractor with the blower engaged and tossed a few scoops of snow into the running blower near the outside edges and the snow was funneling towards the center of the blower. I really don't think this is an issue but I'm not 100% and truthfully I think I kept the augers on their shaft during the rebuild.
I'm trying to rack my brain on what could cause such a loss of performance. I checked the sprockets and the chain has about 3/4 - 1" of defection compared to the 1/4" the manual states so I can change that but I doubt that would mean poor performance but rather a loud racket.. I could be wrong. I've also noticed that it's got a minor vibration which doesn't shock me due to the amount of bearings that I had to remove and reinstall - also not ruling out a bent PTO shaft due to the initial incident. If it's bent it's not that bad and I can live with it but I can feel it in the steering wheel which was never a thing.
I've got a kubota dealership about 15-20 miles away but before I dig out my trailer (which is in the back 40 with a lot of white stuff between it and the driveway). I really hate to pay someone else to do it but unless it's something foolishly easy or a complete mental blunder from myself I'm not too far from bringing it to the shop just based on the ability to find time to fix this..
Do you folks have any recommendations to look at? I mean, this is a pretty simple device so there's only so many things to check and/or confirm.
Just for context I've got an 2007 BX2350 and the snowblower is right around that same age (came as a package).
Thanks all!
Dustball
2016 B2650HSDC
Sep 15, 2023
521
384
Hudson, WI
Are you actually running at full RPM?
Too large of a gap between the impeller and impeller housing? Consider doing a snow blower impeller mod - search Google to get ideas of how it works.
BAP
Dec 31, 2012
3,178
1,295
Post some pictures of the snowblower snowing the augers and blower portion. It will help with giving advice. Check the gear on the chain drive to make sure it is Not slipping on the shaft. Should be 2 set screws and a key. Could be the key has sheared off or missing allowing it to slip on the shaft.
RealMainer
BX2350
Dec 4, 2025
New England
I checked and the key is in place with only one set screw. I've just ordered the second set screw but I can't imagine that missing screw (not the one on the key) would cause bad performance but hey, I'll try it! I'm not sure if these pictures help but this is where I am.
sagor
Jan 9, 2017
308
89
Sudbury, ON, Canada
If you hit that branch hard enough to shear the drive shaft, I would suspect you may have stripped some teeth inside the auger gearbox. Have you checked that? Not sure how easy it is to open it, but worth checking..
EDIT:
Watched this video, similar problem where auger and fan were spinning but not in sync/loss of power to auger. Maybe not your problem with fan throwing snow however... In this case, was missing the spring pin in the drive shaft to worm gear:
Toyboy
BX2230D - RCK60-22BX - BX5450
May 18, 2010
710
1,066
Hayward Wi
By looking at mine, both augers are in the same orientation on the shaft. Your right one looks off about 1/2 turn in relation to the other.
Would that make a difference ???
Dustball
2016 B2650HSDC
Sep 15, 2023
521
384
Hudson, WI
That's how it should be- one 180 degrees from the other.
Yours is incorrect and you should rotate one of them.
Dustball
2016 B2650HSDC
Sep 15, 2023
521
384
Hudson, WI
Factory set new. I've not sheared a bolt yet.
Augers are alternating on the manual cover page and in almost every BX5450 image found on Google and YouTube. Someone assembled yours incorrectly. It's not about shearing a bolt- it's about efficiency when transferring snow from the augers to the fan.
Toyboy
May 18, 2010
710
1,066
Hayward Wi
Curiosity got the best of me today, so I looked at the manual and your right. Mine was assembled wrong . Either at the factory or dealer. Never shearing a auger bolt, I just never had to pay any attention to the orientation. Been running 7 yr like that. Worked fine too. It'll get changed now.
Thanks for setting me straight.
6,289
FYI. if you replace that 'finger guard' shown in the picture ,post #9, with a piece of UHMW, the snow goes a LOT further.
I assume the 'alternating' augers keeps too much snow from plugging up the blower section ?
ShaPow!
10
North Idaho
" 'alternating' augers keeps too much snow from plugging up the blower section"
The "alternating" augers is to keep a constant feed of snow feeding the blower. If they are in the same state, you would feed a lot of snow to the blower, then no snow, then a lot, etc... Alternating them should provide for a more even feed all the time.
