How is the max rpm capped with a D1005 engine?
Ursa Minor Beta
Beta Marine 25 ( Kubota D1005 )
Aug 31, 2025
26
The deep ocean
As I am currently scouting for a replacement D1005 I came across various second hand offers which have different HP at RPM specs.
It seems that the normal D1005-E3B is rated at 25HP at 3600 RPM.
But I also came across one for example with 22HP at 3000 RPM
Is that cap done with governor weights or with the shims under the injection pump?
Or even more complex?
Thanky!
9,909
Thanky!
It's more complex on a D1005.
It could be a combination of several parts and adjustments.
Ursa Minor Beta
Aug 31, 2025
26
The deep ocean
Ah. Ok. I see.
I am getting a bit confused about the different versions of the engine.
I guess though that 22@3000 is not sooo different from the 25@3600
Was wondering if these refer to sustained running or max peak for a short term?
