B2100 3-point hitch
N4NV
L4850
Nov 4, 2023
11
California
My neighbor has a B2100 tractor that was given to her. The 3-point hitch does not go up or down when moving the lever (it is currently in the down position). Any suggestions on what to look for first?
Vince
3,054
Look at the lever bottom end. It is probably an eye with a rod through it. The rod should go into the tractor case. The rod should rotate with the lever movement. There is usually a pin that connects the eye to the rod. It may be sheared and not moving the rod. I could not locate this in the illustrated parts list so I am not 100% sure how it is connected. Just make sure the rod is moving along with the lever’s movement.
Flyingcritters
B2100, L4580 B25X
Dec 2, 2025
14
23
Gilroy, CA
When I lift up the 3-point hitch by hand the lever moves, so I am guessing it is connected.
10,979
There is a round knob under the seat, three point drop speed adjustment, check that it's not in the lock position.
3,054
I am pretty sure that lifting the arms by hand should NOT move the position control lever. But there is a feedback rod mechanism that could be doing that so maybe that is part of the problem?
This diagram is from the Kubota site
The right side (facing tractor from the rear) short lift arm is highlighted in red below. Connected to that is the feedback rod mechanism that is highlighted in yellow below. The feedback rod is connected to the control valve inside the tractor. It tells the control valve the position of the arms and the control valve then tries to make the lift arms return to the set position if they move. See if that is all connected together but not frozen together at the ends (some movement is required).
N4NV
L4850
Nov 4, 2023
11
California
Thanks. I seems like it is not getting any fluid. I guess the first thing I should check is the oil lever.
