BX 3pt turnbuckle issue
Tad Boldan
BX
May 30, 2021
Minnesota
I have a newer BX with a new rear blade added this year. The factory turnbuckles won’t thread in or out with the jam nut loosen. I know about telescopic stabilizers that can be purchased and I will be doing that next spring for dirt work. For now, I want to figure out how to get the turnbuckle stabilizers working for winter plowing. Could these already be bent just slightly enough to create this issue?
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
Probably some dirt or corrosion. Give em a shot of penetrant and get a little more physical
3,046
I assume you mean the stabilizer (side to side) turnbuckles that limit movement of the lower arms.
Those can probably be easily removed from the tractor. Then you could soak them in penetrating oil overnight (I use PVC pipe with a glued on cap as the tank and install a cap or plug at the other end).
Then put it in a vice and see if you can get it moving a little bit in each direction. If so you have won the battle! Just keep working it a little bit and spraying a good penetrating oil (PB Blaster or Kroil or…) on the threads. Don’t get too aggressive or you will twist the threaded section off!
And as mentioned above, one end of each stabilizer is left hand threads and the other is normal right hand thread. That is why I suggest the “both directions“ movement so if either is all the way in you won’t just be increasing the amount of stress on the threads!
10,941
JimDeL
BX2380; 54" MMM; FEL w Pirahna bar; Ballast Box; BXpanded skid plate.
Aug 31, 2022
460
534
NE Ohio
How much do you want to mess with them.
$60 eliminates that issue:
or here: Amazon.com: E-K2561-38300-FR Stabilizer Kit for B & BX Kubota BX1500D, BX1800D, BX2200D, BX1830D, BX2230D, BX23, BX1850D, BX2350D, BX24, BX1860, BX2360, BX2660D, BX25, BX1870, BX2370, BX2670, +++ : Automotive
Vlach7
L47 305DT JD500C
Dec 16, 2021
452
329
Frazier Park Ca
Tad Boldan
BX
May 30, 2021
Minnesota
PaulL
B2601, MX5200.
Jul 17, 2017
2,790
1,787
NZ
Agreed. I just thought there might be an old school idea that would work for now. All I’m doing is scrapping snow. Next spring I will need it to cut more and that’s when I will put on the better set up.
Thanks again.
Before I replaced them with sliding stabilisers, my old BX had very stubborn turnbuckles. A bigger wrench was usually my answer. But yes, there's a threshold where they'll break. You could replace them with some wire for the winter - so long as both sides are tight it won't sway much.
