Found off-road diesel
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,987
2,362
Western MT
It's pretty common around here, but I live in a rural area.
11,757
Common here too. It's sold at the gas station a couple of miles from my house and all over the valley.
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,346
868
under a rock
I run Home Heating oil
currently $2.83 a gallon delivered.
WFM
L3800
Apr 5, 2013
1,573
1,051
Porter Maine
My nephew and lots of other younger folks with diesel pickups run the off road diesel here about $1. A gallon cheaper.
11,757
In Montana, $.54 per gallon no matter what the diesel price goes up to or down to.
So given that the fine is $500 for the first offense for running off-road diesel on the road, you'd need to get away with running around a 100 gallons to break even. Make it to 1,000 gallons and you're doing well. 😂
jyoutz
Jan 14, 2019
3,626
2,719
Edgewood, New Mexico
Not to mention a red dyed fuel system in the truck.
PHPaul
Apr 2, 2015
1,307
1,646
Downeast Maine
www.eastovershoe.com
Yup, me too. Every Fall I have them top off the tank for the furnace in the shop and the tank for the tractor. That and a healthy dose of Power Service in the tractor fuel and I'm good for a year.
Both 275 gallon tanks, actual fill is about 250 gallons.
jimh406
Jan 29, 2021
2,987
2,362
Western MT
From what I understand, the dye is designed to be almost impossible to get out of the fuel system. I have no idea who's checking for it.
5,678
Yeah thats all fun and games until they get stopped and they dip the tanks,, then it gets expensive
johnjk
Apr 13, 2017
1,816
2,236
West Mansfield, OH
Interesting thing is the nozzle for off-road is a larger diameter than the taxed diesel. Do diesel pickups have the same restricted opening that a gas vehicle has? Now comes the fun. We had company when I got home so the tank is still in my truck. Time to warm up the orange and move it
11,757
I've never found a diesel nozzle that won't fit in the fuel filler necks of my '02 F-250 and '24 F-450. Up here the nozzles are the same size for off-road and on-road diesel. Some fuel stations that see a lot of commercial vehicles have the larger nozzles and a higher flow rate, but they work just fine.
Someone needs to invent an adapter that prevents foaming of the diesel fuel. If I want to get a full tank I have to wait for the foam to settle which makes refueling a longer process than it should be.
7,704
I've seen troopers dipping fuel at farm sale barn. Don't know if they work off of a tip or just decide today is the day. Probably know that is the place for a lot of trucks and most farmers have access to both fuels.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,979
Near Lancaster, PA, USA
Sounds like unreasonable search to me.
armylifer
Mar 26, 2013
2,331
1,086
Thurston County, WA
My understanding is that vehicles used for farming are exempt from road use taxes. Some states even have special license plates to identify farm trucks. Also, if you are using on-road (taxed) diesel in a farm truck you can deduct the taxed portion of the fuel you use on your federal income taxes. Some states also allow this exemption for state income taxes.
3,148
What would happen when you sell a farm use truck to someone who is using it on road? I am assuming the tank would be stained red but the off road fuel would be dumped and refilled with on road diesel? So why would it matter if the tank gets stained?
