Finding an appropriate sized tractor (hp) with a cab that's big enough.
9,757
I was visiting a good friend and his mother this past weekend over in Kettle Falls, WA. He's 73 and his mother is 97 and still going strong. Turns out it was a working visit and I spent Monday shoveling gravel out of his Ford Super Duty, crawling around under his truck to drain the water separator (it had no water) and looking for the source of a small coolant leak. Turns out that he's really good at giving directions unless it's the location of the water separator! 😂
After I had completed my chores we headed to Colville to look at tractors. He's been wanting a tractor ever since moving back home from Hawaii almost four years ago, so we stopped by the nearest Kubota dealer in town. He's on 6 acres and could really use a tractor. He has a lot of downed trees and I mean a lot. He needs to move snow, has some tilling to do each year for his mum, he needs to mix up the compost pile and spread it around, cut grass, spread gravel, etc. Something in the 25hp to 40hp range would be perfect for him but he could really use a cab. The problem is that he's 6ft 3in and simply doesn't fit in the cabs that come on 40hp and smaller tractors. Heck, I got in the cab of the L4060 shown below and there's no leg room in that thing. The width is ok (a bit tight), the height is excellent, but the lack of leg room is ridiculous. I'm 6 ft and have no problem getting in and out of my MX or M, but there's no way I'd buy an L4060 given the size of the cab. I don't think I've ever sat in a Kubota cab smaller than an MX5400/L6060 and was really surprised by how small the L4060 cab felt.
So now I don't know what the best solution is for him. Perhaps and open station is the only realistic option, but is the leg room any better? An MX5400 or L5460 (or bigger) have good cabs that most will fit in and be able to get in/out of fairly easily, but that's too much tractor for his needs. He's on a fixed income so not looking to spend $50k to $60k on a tractor that he's going to use 100 hours or less a year.
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
59
Lakes Region, NH
I'm 6ft 4in and I am very comfortable in my LX4020 cab with adequate leg room and a comfortable seat.
9,757
Might have to look at other brands to see how the cabs are.
I don't think the problem is unique to Kubota but I did suggest that he stop by the TYM dealer in Colville and the Kioti dealer in Chewela and see if he fits in any cabs on 40hp and lower tractors.
9,757
I think the Lamborghini R8 has a fairly spaceous cab:
Yeah, and I'll start calling him Jeremy! 😂
He got up in the M4-071 cab and was way more comfortable, but he found it to be a long way up and down, not to mention that the tractor would be unsuitable for his place. The instructor/buddy seat didn't help though. I don't have one in my M6060 and after experiencing how much it gets in the way I don't want one.
9,757
Everyone's idea of "adequate" is different, and as mobility and flexibility deteriorate, what once might have been adequate is now unacceptable or even dangerous. We see this all the time with members adding steps to their tractors to help getting on/off. I'm years away from needing that, but I understand that it's essential for others.
Hugo Habicht
G1900
Jun 24, 2024
942
1,324
Ireland
You can always throw out this extra seat, I'd imagine.
Or possibly higher the seat with spacers if adjustment range is not sufficient. Just an idea...
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,848
2,256
Near Lancaster, PA, USA
My L4240HSTC fits me just fine. I'm 6'-3" and 270#. My version came with a comfortable cloth seat. Note that I DID adjust the typical Kubota forward tilt out of it*. I'm not sure it's slid all the way back and there's plenty of legroom. In recent years Kubota has been introducing their "X" variations and confusing me on just how big / small different models have become. It is the most nimble and user-friendly tractor I've owned.
* I replaced the front two seat mounting bolts with longer bolts and locking nuts. I modified the seats on all 3 Kubotae I've owned because it felt like they were trying to dump me into the steering wheel.
9,757
I don't like having my knees over my feet when operating a tractor. I find that position awkward at best, and my friend finds it intolerable. There is so much more room in the MX6000 cab compared to the L4060 cab (legroom and width), and I learned that those smaller cabbed models wouldn't work for me or for my friend. I like to rotate my torso in the seat when running implements out back and I find that easy to do in both cabs. The M6060 cab is even better than the MX, but the MX cab is still very comfortable. I think he needs to look at an MX4900HSTC if he can find one, or at least an MX5400 or MX6000 to get a feel for the cab.
9,757
The buddy or instructor seat could be removed, but I don't really think the M6060/M7060/M4 cab is big enough for that seat, but no doubt some will love it.
One of the many things I like about the M6060 is how easy it is to get in and out of the cab, and how much room there is.
chim
Jan 19, 2013
2,848
2,256
The buddy seat in the L4240 is my lap. Sweet Pea NEVER falls asleep on the road, but she did drift off in the 'Bota about a year ago when she wanted to ride along with Dad.
JimmyJazz
1,270
805
Pittsburgh, Pa
What's this guy weigh?
9,757
Around 280lb I'd guess. He's a big lad and has always reminded me of a bear, but not a sloppy fat bear, more like an older slightly soft bear with big 'ol paws. 😂 He could walk on the set of The Hobbit or Lord of the Rings and require no costume or makeup and fit right in.
The more I think about it, the more sense it makes for him to look at an MX4900. I think he'd do well with that tractor.
Old Machinist
May 27, 2024
539
624
NE FL
They didn't have any LX tractors to try? The LX4020 might suit him.
9,757
I would expect the LX4020 cab to be similar to the L4060 cab in size. I looked on Kubota's website today to see if they provide cab interior dimensions but they don't as far as I can tell, which is a pity. I think that would be useful information.
chim
Jan 19, 2013
2,848
2,256
I'm not really familiar with the LX models, but have read about them being a bit smaller in areas when compared with the Standard or Grand models. Haven't seen spec sheets showing the dimensions of the cabs on LX vs L cabs, but the salesman in the video below mentions a bigger guy being more comfortable in the L60 series at around 6:00:
jyoutz
Jan 14, 2019
3,451
2,533
Edgewood, New Mexico
The LX series are in-between a B and L series, so they are smaller than an L series by design.
9,757
After sitting in that L4060 cab last Monday, there's no question that it's significantly smaller than the MX cab. I've sat in an L6060 cabbed model but that was four or more years ago and I don't remember thinking anything other than nice tractor. The L4060 and L4760 are smaller than the L5060, L5460 and L6060 models, so it stands to reason that the cabs are bigger in the 50+ hp variants. It would be good if my friend could head over this way and spend some time in my MX to give him a better idea of what it's like to use a tractor of this size. That won't happen until the spring though.
steveh
Kubota L4701, forks, Land Pride rear blade, Wallenstein splitter
Dec 1, 2020
72
47
Rocky Mountains
Only thing he can do is go sit in various models and see. 280 is pretty hefty and he's tall. I am 6' 1" and skinny and fit with plenty of extra room on my L4701. I haven't tried any cabs so cannot say how I'd do. But climbing aboard different models and maybe even driving them around the dealer's yard will by the only way to really tell. Is he totally set on a cab? The 4701 is about 47 Hp, 4 cylinder.
