Modification to Fluid Return Rubber hose
gbaker53
Kubota B2401DT&FEL RockRake, Rear Blade, Cultipacker, SeedRake, Driveway drag,
Mar 28, 2025
153
115
NC
I did the modification to the original rubber hose that low pressure fluid runs through back to the fluid tank. After removing the tire and losing the fender to access the rubber hose and removing it from the tractor and cutting it to splice in the Tee fitting, I realized that my best option would be to replace the rubber hose with some more flexible rubber hose. I had some in the shop and I made the two sections that I needed for the new hose. I was able to get it installed on the tractor and get it all back together. The first pic is the old hose that I had cut and the new hose that I made with the Tee and the hose installed that I will connect to the T port on the hydraulic control valve. The next pic is the new rubber hose and tee with the valve hose installed to the tractor. The mod that I did required an additional change to be made before it would actually work, I had to make the more curved hose section about 3 1/2” longer than the original version. This was required to be able to bend the hose to get the modified hose connected to the tractor without having a kink in it so there would be no flow restriction.
10,950
Please stop making a new threads on every aspect of your project.
Just put them all in the original thread.
You need to do it because making new threads, makes it near to impossible to follow where your going with anything.
7,197
Keep it simple - one tee and three clamps!
gbaker53
Mar 28, 2025
153
115
NC
I wanted to be able to thread the hydraulic hose from the valve to the fitting so that is why I used the tee fitting and the two barbs to attach the rubber hoses to it. I had considered using a three barb fitting but went with what I used!
gbaker53
Mar 28, 2025
153
115
NC
I will do it! Maybe I can get the posts all together in the Modification section.
7,197
You are olanning on a DIY guide for others but you are over complicating things with this insistence on using pipe fittings.. Its a low pressure line. Cut the male pipe end off that hose and use a clamp.
Better yet, as I said in an earlier post about using that return scrap the high pressure hose altogether and use something like push-lock hose and fittings. Thats cheaper, more compact, neater, and what the OEM did.
gbaker53
Mar 28, 2025
153
115
NC
Well I do appreciate your opinion but I have done it with the fittings and hose I had so I will go with it.
gbaker53
Mar 28, 2025
153
115
NC
Did a little more on my B2401 tractor today. I decided that I should move the 4 AG coupler further back because when the hoses were/are attached to the couplers even with an elbow fitting on the coupler the hoses would obstruct the seat being completely down and resting on the springs and seat contacts as require. So I added a piece of flat steel to the bracket I had made for the 4 AG coupler and got it painted, tomorrow I will reinstall the coupler bracket on to the steel extension and reconnect the hoses. Did get the hose routed out to the valve location ensuring that nothing was going to be able to cause damage to the hose.
Just waiting on the new valve and PB sleeve adapter to get here so I can get this project completed.
gbaker53
Mar 28, 2025
153
115
NC
I didn’t do much in the last few days on my project but have been waiting on parts to come in slowly. The holiday season shipping has started slowing everything down. As I did a slight modification to my support bracket for the 4 AG couplers with bracket. After adding the metal plate to my support bracket so it is towards the back more as the seat was hitting the hoses. Also did a little modification to the seat bracket to move the seat forward about 2 inches! After I got that done, I was able to reattach the hoses to the couplers and now I don’t have any problems with the hoses being too close to the seat and rubbing against the seat back. Hopefully my remaining parts will get here soon and I can get this wrapped up. We have gotten a good bit of rain the last day or so and my 1000’ drive way is in pretty rough shape! Looking forward to having the top and side links working, that will really help me with the maintenance of my driveway.
