9 Worst Things You Can Do to a Diesel Engine
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,200
1,193
E.
  • Letting the fuel tank run low. ...
  • not keeping up with oil changes. ...
  • Using the wrong type of fuel. ...
  • Cold starts without proper warm-up. ...
  • Overloading the engine. ...
  • Skipping coolant changes. ...
  • Neglecting filter maintenance. ...
  • Ignoring warning lights. ...
  • Failing to keep the engine clean.
FWIW: the following came from a diesel tech course put out by UTI earlier this year. Part of their 45 week diesel training course
Not keeping up with oil changes
Skipping oil changes is one of the fastest ways to wear down your diesel engine. Over time, engine oil loses its lubricity as it breaks down from heat, pressure and contamination. As the oil ages, it becomes less effective at reducing friction, absorbing heat and suspending harmful particles. In diesel engines, where internal pressures and operating temperatures are often higher than in gas engines, this breakdown happens even faster.
Contaminants like soot, fuel dilution and metal particles can accelerate wear on vital components such as bearings, pistons and turbochargers. Sticking to a regular oil change schedule based on your engine’s workload and manufacturer guidelines is essential to maintaining performance, preventing costly damage and extending the life of your diesel engine.
Running a diesel engine on a near-empty tank can cause serious problems. Sediment and contaminants naturally settle at the bottom of the tank, and when fuel levels drop, these particles can be pulled into the fuel system, clogging filters, damaging injectors and reducing fuel flow.
But the bigger concern is air entering the fuel system. Diesel systems rely on consistent pressure and flow, and introducing air can lead to hard starts, engine misfires and, in some cases, injector damage due to improper lubrication and cooling.
Low fuel levels can also increase the risk of moisture buildup, especially in environments with temperature swings. The more space in the tank, the more room for condensation to form, which can lead to microbial growth and fuel degradation. To prevent these issues, it’s best to keep your diesel tank at least a quarter full whenever possible.
Diesel engines require diesel fuel, plain and simple. Accidentally using gasoline in a diesel engine can cause severe damage. Gasoline lacks the lubricating properties that diesel fuel provides, which are essential for protecting high-pressure components like fuel injectors and the fuel pump. Without proper lubrication, these parts can quickly overheat, seize or wear prematurely.
In addition, gasoline combusts differently than diesel. It can ignite too early in the combustion cycle, causing engine knocking, misfires and potentially catastrophic damage to pistons and valves. Even a small amount of gasoline can disrupt the entire fuel system and may require a full flush to prevent long-term issues.
Using the wrong grade of diesel (e.g., #1 vs. #2, or off-road vs. on-road diesel) can also impact engine performance and emissions compliance. Always double-check the pump before refueling and make sure you understand which fuel type your vehicle or equipment requires based on climate, application and manufacturer recommendations.
Diesel engines don’t respond well to cold starts, especially in freezing temperatures. Starting the engine without allowing it to warm up can cause incomplete combustion, rough idling and excessive engine wear. Cold temperatures thicken both diesel fuel and engine oil, making them harder to circulate through the engine. Thickened oil struggles to reach critical components quickly, increasing friction and wear during those first few moments after startup.
Diesel fuel can also gel in extremely low temperatures, restricting flow to the injectors and fuel pump, which may lead to hard starts or stalling. This is especially problematic without the right winter blend or fuel additives.
To protect your engine, use block heaters, glow plugs or intake heaters to warm the engine and fuel system before starting. Letting the engine idle for a few minutes gives oil time to circulate and ensures the fuel reaches the right temperature for proper combustion, reducing stress and wear on internal parts.
Pushing your diesel engine beyond its limits by hauling loads heavier than it’s rated for can cause excessive stress and long-term damage. Overloading increases engine workload, leading to higher operating temperatures, reduced fuel efficiency and accelerated wear on critical components.
When the engine is forced to work harder than intended, internal components like pistons, bearings and valves experience more friction and pressure, which shortens their lifespan. The added strain can also affect the transmission, drivetrain, suspension and braking systems, putting your entire vehicle at risk.
Prolonged overloading can even lead to thermal breakdown of engine oil, decreasing its effectiveness and further compounding wear. To ensure safe and efficient operation, always stick to your vehicle’s recommended weight limits, including the gross vehicle weight rating (GVWR) and tow rating, and evenly distribute loads to avoid unnecessary stress on the engine and chassis.
Coolant helps regulate engine temperature and prevent internal corrosion, making it critical for diesel engine health. Skipping coolant flushes allows the coolant to degrade over time, reducing its effectiveness and exposing the cooling system to serious risks.
When coolant breaks down, it loses its anti-corrosion properties and can become acidic, leading to rust, scale buildup and clogged coolant passages. This restricts flow and reduces heat transfer, causing the engine to overheat. Degraded coolant can also damage the water pump, radiator and head gasket, potentially resulting in costly repairs.
Signs of bad or failing coolant include:
  • Rusty, sludgy or discolored coolant
  • Persistent overheating
  • Coolant leaks or low levels
  • Sweet smell under the hood (indicative of a leak)
Regularly flushing and replacing coolant based on your engine’s maintenance schedule helps keep temperatures stable, protects vital components and extends the life of your diesel engine.
Diesel engines rely heavily on clean air and fuel, making filter maintenance critical. Dirty air filters reduce airflow, leading to poor combustion, increased fuel consumption and power loss. Clogged fuel filters can restrict fuel flow, starving the engine, damaging injectors and causing hard starts or stalling.
Over time, neglecting filter maintenance doesn't just impact performance; it can lead to long-term engine damage. Insufficient air or fuel flow can result in incomplete combustion, which produces more soot and unburnt fuel. This buildup can clog exhaust gas recirculation (EGR) valves and coolers, reducing their efficiency and contributing to higher emissions, rough idling and even EGR system failure.
In severe cases, dirty filters can lead to increased crankcase pressure and contamination of engine oil, accelerating internal wear.
Dashboard warning lights are there for a reason. Ignoring signs like the check engine light or glow plug warning can turn minor issues into major repairs. Address problems as soon as they appear to prevent further damage and avoid expensive breakdowns.
Dirt, grime and oil buildup can hide small leaks and lead to overheating or contamination. A clean engine compartment helps you spot issues early and ensures proper airflow for cooling. Regular cleaning also extends the life of hoses, belts and seals.
MapleLeafFarmer
Dec 2, 2019
1,200
1,193
E.
The 9 things listed would apply to ANY engine. :unsure:
agree!
but given a lot of stuff I see posted about problems, people miss the basic basic stuff that seems so often oblivious to others. (oil questions, won't start cause hst/seat/gear satey swith, etc...
Blue2Orange
Apr 3, 2025
435
303
Bayview Township
An issue I've noticed with the BX is the relatively significant swing of the fuel gauge from heading up or down a steeper pitch and/or when on a side hill. Has me thinking a minimum of half of a tank of fuel when measured while siting level to be on the safer side.
At that mark right now. Local fuel stations have yet to replace summer with blended or winter grade diesel. Hopefully soon. Daytime highs are forecasted to be sub-freezing for at least then next 10 days. Do use PowerService anti-gel/cetane booster for winter diesel. Minimal cost for the hours run. 24 winters of use on the old NH. Zero starting or fuel issues. Plan to continue with the BX.
3,090
Add another
babying a diesel ......... really bad for it - worse than 100% WOT
Newer diesels with Tier IV - idle is an enemy!!!
People that do not understand how the rings work on a diesel cannot see that working a diesel is ACTUALLY good for it, less and less particulates get into the oil via the rings when a diesel is worked as designed.
Blue2Orange
Apr 3, 2025
435
303
Bayview Township
I did baby the diesel during the 50hr break-in. RPMs and very light loads with the implement. Slowly increased the working rpms, but nothing close to RPMs needed to spin the rear pto at 540. Small diesel seems to run at much higher rpm. Old NH ~2400 rpm got the pto up to 540. The BX is requires ~1000 more rpms. +55 hours. First snow storm forecasted to kick in after sunset. LOT(Little Orange Tractor) might experience +3000 rpm for the first time.
JRHill
Orange: B7100 Std and Woodmizer; Green/yellow JD Buck, Gator and 410j.
Apr 26, 2016
283
235
Wahkiacus, Washington
Add another
And yet another: Using the diesel engine like a gasoline engine and not knowing there are differences. This really became an issue with cars and pickups - not so much tractors.
Like the folks who cold start ANY engine and race the heck out of it for some unknown reason. This is a mortal sin to do to a diesel, in my opinion.
Flintknapper
L2350DT
May 3, 2022
2,024
2,579
Deep East Texas
Father-In-Law guilty of ALL nine of them. Probably some other less nefarious infractions as well.
Bearcatrp
Mar 28, 2023
1,395
1,012
Minnesota
What, I can’t operate it like I stole it?
Mark_BX25D
Bx25D
Jul 19, 2020
2,112
1,616
I try to keep all of my vehicles at a quarter tank or better. My property is reasonably flat, so I think I'm good with that.
11,248
Missing the #1 rule, don't loan it to the neighbor / friend / brother in-law... and so on!
Reactions: 12 users
MapleLeafFarmer
Dec 2, 2019
1,200
1,193
E.
hmmm.... decisions, decisions, decisions!!
now that's one that's hard to argue with but when you have hired hands and family on the payroll something that can't be avoided. 😢
Blue2Orange
Apr 3, 2025
435
303
Bayview Township
Only options for diesel fuel up here are #2 in the warm months, winter blend, and then maybe the option of #1. Never have seen a biodiesel pump, but then we have a total of 3 gas stations split between the 3 communities along the south side of the peninsula. 1 more I think on the only island with a year round population.
Probably a good thing. I was unaware that biodiesel has a relatively short "shelf life" and a higher risk of algae or whatever to develop.
OT: would be nice if Kubota would have a direct from the factory clean out hatch for the fuel tank.
SDT
Apr 15, 2018
3,704
1,422
Bingo.
I may agree to help friends and neighbors with some jobs but NEVER loan equipment.
MapleLeafFarmer
Dec 2, 2019
1,200
1,193
E.
now that's a great idea Kubota should consider. assuming space exists.
A big screw in bung at the bottom of the tank to drop the fuel / drain the tank of sediment or bio-nasties that may happen from time to time.
JonM
Nov 29, 2024
288
679
wisconsin
the fuel pickup is in the bottom of the tank at the lowest part from what i understand.... any sediment in there doesnt care about levels
7,715
Many fuel tanks has a spacer ring with the top above the bottom of the tank 3/4" or so where the line leave the tank. This prevents some heavy trash from getting into the fuel line.
