M5111 auxiliary front work lights
biffog
L345DT & RTV900
Sep 30, 2019
26
Curragh, KE, Ireland
Hi, recently purchased a used M5111 and upgrading the work lights to LED. I noticed there are two extra connections beside the front inidicator lights, parts diagram seem to suggest these are extra work light connections, but no power on them when I turn on any light a switch. Any idea where they are connected? Do I need to add a switch for them?
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
Congrats on the tractor and welcome aboard!
You could check to see if the extra wires have been taped over with the wires that feed the amber lights. My L4240 didn't have rear work lights from the factory. There were wires with a plug on them that were hidden under black tape near the rear "lollipop" amber lights. The plug wasn't something I could easily find so I simply spliced them onto the work light tails.
For the switch, there was a plug behind one of the blanks on the little overhead switch group in the cab roof.
Bee-Positive
Nov 16, 2022
967
925
Amsterdam, NY
Looking at the diagram it seems the wires go back to the fuse block. Is there an empty slot in the existing fuse block? Maybe they didn't put a fuse in because nothing was hooked to that circuit.
Get long leads for your multimeter and check continuity between the plug end and the fuse block.
#40Fan
585
421
If you want plug and play, you'd likely need to buy that switch. If you don't mind cutting the plug off and running your own switch, $5 would get it done.
3 pole rocker switch.
There will be a power in, power out and a ground for the light on the rocker. If you don't need the light on the switch, get a 2 pole rocker.
