Poor man's top and tilt
Bisleybob
B7500
Aug 15, 2020
Harding Pennsylvania
So, I had some hydraulic stuff reclaimed from other projects, and decided to do something with it. I do expect to rebuild the chief tie rod cylinder sooner than later, as it has been in the weather for some years. The top link got some weld on rod ends, and the side link got one rod end cut off, and some left over steel scraps welded on.
Bisleybob
B7500
Aug 15, 2020
These old l series have very tight operating stations, so I mounted the valve on the fender, and it actually doesn't hamper the loader valve or the 3-point valve lever. I will end up adding 90 degree fittings on the top link, and tidying up the hoses a little more. The hoses are about 5 years old, and will be replaced as necessary with a more appropriate length. The valve has float, and it's function is on the side link.
Bisleybob
B7500
Aug 15, 2020
Here are some photos with a back blade, although this will be more effective with the box blade. I did use it for about an hour, and it worked as expected. 20251123_124800.jpg 20251123_124512.jpg 20251123_124442.jpg 20251123_124429.jpg
Reactions: 8 users
7,623
Nice! Think I'd have to take the valve control rod and bend it into an "S" so I could get to it easier though.
7,203
PHPaul
Apr 2, 2015
1,276
1,583
Downeast Maine
www.eastovershoe.com
Nice! I did essentially the same thing. The top link worked for years before the stress blew out the seals. I replaced it with a purpose-built top link with check valves.
Same deal on the tilt cylinder. Plain cylinder worked but wouldn't hold position for long, added check valves and all is well.
2001TLB
L48TLB, 60" EA SSQA Root Rake Grapple, EA SSQA Fork lift
Nov 14, 2021
71
57
Shelton, Washington
