Finding 8" wheels trailer brakes
Rosohatica
Kubota L3200, Tehnos MULS 130 flail mower, Fužinar 14” plow, Landforce 5′ tiller
Feb 23, 2022
234
106
Zagreb, Croatia
Hi, recently I have purchased dumper trailer. Thanks all who helped me choose. Here is the previous thread Dumper trailer choice
Some of you also recommended getting brakes, so it got me thinking, and I really want them now :) Wheels of the trailer are really small. Look at the image attached. Russell King suggested to look at this page and it was really useful because I think I was able to track them and I think they are of a this kind: https://www.etrailer.com/dept-pg-Trailer_Tires_and_Wheels-pc-8_Inch.aspx
But I couldn't find brakes for such small wheels https://www.etrailer.com/dept-pg-Trailer_Brakes.aspx
I was aiming at electrical brakes, but would be happy with any I guess. I searched the internet and couldn't find much except that such wheels are used on ATVs.
And then I managed to find this:
Can you tell if this would work for my case? And what else do I need? It looks like these brakes should connect to some kind of a brake cable?
Thanks in advance.
Rosohatica
Feb 23, 2022
234
106
Zagreb, Croatia
Thanks. So I need both? Hub and drum assembly as well as brakes? Sorry I am completely clueless about this. I guess the first is like a cup within which there are brakes? It says 7" in the title (diameter of the drum I guess) but in description it says it is for Wheel size: 10" to 13". Would that would work for 8" wheel, which I THINK my is?
10,986
Yes you buy the hubs and then the brake setup to match.
If the inside of the rim is too small then you would need to go to a larger rim size to accommodate the brake drum.
You would also need to check the spindle size and length to make sure it matches what you need.
Orangeglow
2015 BX2370
Jun 19, 2014
408
222
Prescott, Ontario
Out of curiosity, why do you think you need trailer brakes ? Is it for pulling the trailer behind your tractor or vehicle ? Would you prefer electric or hydralic ?
3,056
@Rosohatica
Go to this page and move to the bottom to read articles about adding electric or hydraulic brakes.
You should see something like this
From my memory you would be able to buy brakes that can bolt onto most normal trailer axles. I am not sure what your axles are or if they have been prepared for brakes. These articles should lead you through a process and that may require a new axle. You may need to call and see if they have brakes for your off road trailer or if they are even manufactured.
Rosohatica
Feb 23, 2022
234
106
Zagreb, Croatia
@Orangeglow , the main reason I’m considering brakes is the downhill section. I can avoid collecting firewood in places where I’d need to go downhill with a full trailer, and I have a winch, so I can always drag the logs to a flat spot first. The real problem is getting the empty trailer out of the garage. The garage is on a hill, and to reach the gravel road I have to go down that slope.
Last winter, when the ground was frozen, I went down that same hill with just the tractor and it started skidding—the rear end began sliding sideways, and for a moment I genuinely thought it might roll over. Now I’m trying to imagine that same situation with a trailer behind me pushing, even if it’s empty.
My tractor tires aren’t in great shape either, so I’m considering new ones and possibly chains. I’ll try to avoid ice when I can, but the hill has no pavement—just grass and mud—so it’s slippery even when it’s simply wet. I’m planning to install honeycomb concrete path grids in two tracks, which should help in the future.
Rosohatica
Feb 23, 2022
234
106
Zagreb, Croatia
Thanks. I guess I need to take off the wheel first to inspect everything. Could you tell based on the photo only if its compatible with brake drum of any size at all? From what I have read it could be with either machined bearing seats, a seal surface (needed for brake modification), or it is only a straight garden-type stub axle which is not compatible.
Rosohatica
Feb 23, 2022
234
106
Zagreb, Croatia
@Rosohatica
Thanks. I will take off the wheel first to see what I have. Will have to wait for another weekend unfortunatelly because the trailer is not where I live.
Rosohatica
Feb 23, 2022
234
106
Zagreb, Croatia
I would prefer electric. But given the current situation, I will not be picky 😅
10,986
Avoid hydraulic brakes if you can as the controller for it is EXPENSIVE!
Kennyd4110
Vendor Member
Sep 7, 2013
1,515
901
Westminster, MD
www.boltonhooks.com
My 2C:
Brakes (on the trailer) are not your solution, chains and maybe new tires are.
I do not believe a typical electric brake controller will work on a tractor well, most rely on inertia to activate and moderate the voltage to the brake circuit, you will not have much inertia for it to sense going 1MPH down an icy slope, so you'd have to manually control them. Locked up trailer wheels are not going to help you regain control anyway.
Get the traction on your brake axle situated, use 4wd, and you will have full control of both the tractor and the trailer in most all situations.
Rosohatica
Feb 23, 2022
234
106
Zagreb, Croatia
My 2C:
Thanks, which axle is a brake axle? Just rear? Or all 4 wheels have brakes on L series tractor?
lynnmor
B2601-1
May 3, 2021
1,795
1,603
Red Lion
Most models have one brake in the rear, in order to have the front help in slowing the tractor 4 wheel drive needs to be engaged.
Kennyd4110
Vendor Member
Sep 7, 2013
1,515
901
Westminster, MD
www.boltonhooks.com
Both rear wheels should have brakes, but I am unfamiliar with your specific model.
If you put the machine in 4WD (really 3WD since the front diff is 'open'), then the front and rear drivelines are locked together sort of giving you 3-wheel braking.
6,281
NIW is right , you need BOTH new hub and brake backing plate. probably '2000# axle' hubs. Easy tell, remove the hub and if the spindle ( axle...) is straight shaft (NOT tapered), it'll be 2000#. Look at the hub 'axle seal' for a part number, use google to see 'what it fits'. You'll have to fab up some angle brackets to mount the backing plates onto the axle of course. Angle iron works well for those !
As for using ebrakes with a tractor, most controllers have a manual switch to apply the brakes or go old skool, use a 20amp push button to feed +12 to the brakes. YOU can pulse it on/off as required. On steady should lock up the brakes.Power from a separate fuse .Brakes typically draw 4 amps each ( 4x2=8) , so 15 amp fuse should be fine.
