I have a 2008 Kubota BX25 with a BX23 engine. While I was digging with the backhoe, the engine coughed causing me to look at the gauges. The Temperature gauge was pinned at hot. I shut it off pronto. I checked and the coolant was full and normal in radiator ( after it cooled) and in the overflow tank. I pulled the temperature sensor and its resistance was .7 Ohms, a near short. I've got a new one on order. I changed the thermostat. I filled the near empty fuel tank to about 1/4. I changed the fuel filter. Now I have no way to run my BX25 while knowing the actual temperature ( a must). It has the older odd shaped gauge shown in the photo. I ran it about 5 minutes and used a laser temperature gauge pointed at the head and it seemed locked around 125 degrees. That seemed good. Maybe the thermostat I changed was stuck closed? Does anyone know where I can get the old odd shaped temperature gauge? And how its removed? Any thoughts appreciated.
