G1900s weak hydraulics
straytcat
Kubota g1800s lawn tractor
Jan 15, 2025
Minnesota
I've got a g1900s with a 42 inch front mount snowblower, my problem is the hydraulics won't lift it off the ground. No problem with the mower deck, and it will lift the quick attach without the snowblower mounted no problem. Hydraulic fluid is full. Any advice appreciated. Leaking seals? Thanks.
Bee-Positive
Nov 16, 2022
531
548
Amsterdam, NY
Just guessing to see what sticks to the wall...
When's the last time you changed the hydraulic fluid filter?
I would think if you had leaking seals you'd find drips or puddles and/or hyd. fluid in other areas of the engine and the level wouldn't be quite "full".
Maybe air in the lines.
6,256
Start by testing the hydraulic pressure. All it requires is a $15 gauge and an cheap adapter fitting to hook it up. That will give you an indication of where to start looking.
