BX2360 & Titan Chipper - Make Sense?
FattyArbuckle
21
12
Commonwealth of Pennsylvania
Looking for thoughts and ideas, but probably not a sanity check as that ship sunk some time ago.
I'm considering getting a Titan 25 inch chipper for my BX2360. I think EMB Wallenstein is the “standard” but it's way out of my price range; hence maybe the Titan.
I have a small amount of land (2-1/2 acre) but seem to generate a lot of wood trash. Currently, I cut all my branches to 4ft in length and tie up multiple ~25 to 40 pound bundles of branches. Then, once a month, I load the bundles into the back of my car, and take them, in multiple trips, to the township for disposal. Ideally, I'd just make a pile of branches and let them compost, but with only 2.5 acres and too many neighbors that's not realistic.
So, if I get a Titan chipper.....
* Am I expecting too much from a BX2360 ? Will this overload and kill my Kubota ?
* Can the BX2360 power this chipper okay or will I be waiting a lot for recovery between branches ?
* Anyone have experience (good or bad) with Titan – do they hold up ?
* Is this a foolish was to spend my (limited) $ ?
As for experience, I've never used a chipper but regularly use things like a chain saw to drop trees, use a post hole digger, do most maintenance, etc. I expect a learning curve but should be able to use one.
Thanks!
WI_Hedgehog
Apr 24, 2024
1,130
1,647
Milwaukee, Wisconsin, U.S.A.
If you look in my About section I have a WoodMaxx with hydraulic feed and paired with the BX2370 it's a monster. I don't know how that'll work with a Chinese chipper.
One thing to look for is the chipper will blow chips "far enough" since that's a weak point of 3-point-hitch chippers; the WoodMaxx can blow around 15', making a chute so it could blow further stalled out the low-pressure high-volume fan and was worse than no chute. (Though thinking of it I should probably adjust the shoot wider and that should keep the fan from stalling out.)
FattyArbuckle
21
12
Woodmaxx looks like another quality machine that price-wise is unobtainium for me.
6,881
Not sure what price point you’re looking at with Titan. Only 25” I saw on their website was a gravity feed unit “on sale” for $2k. I would find another $500 somewhere and go with the similar Woodland Mills TFG55. Both appear to be light enough for the rated capacity of your 3pt hitch, and both are within your HP rating. Worst case, if you manage to feed it something which causes it to require more power than your tractor can provide, it would stall the engine, but that wouldn’t break anything and isn’t likely anyway. So, no a chipper that size shouldn’t damage your tractor.
Nothing against WoodMaxx; didn’t see anything in their offerings that wasn’t a good bit more expensive.
Titan has sort of a Harbor Freight reputation. Continuing that analogy, Woodland Mills and WoodMaxx may not be Snap-on but they’re at least Craftsman. As always, YMMV.
6,329
hmm, possible options
1) rent a chipper for a day. has to be cheaper than buying a chipper,storing it, etc.
2) make friends with an arborist. trade a space for him to dump a truck load of mulch in exchange for chipping your brush.
3) find a local who WANTS your brush to make his chips/mulch
Mark_BX25D
Bx25D
Jul 19, 2020
2,112
1,616
But where's the fun in that??? :D
The end result there is that you eventually wind up with more mulch than you can handle, and you still have that wood trash being created.
That's even IF you can find an arborist who wants the deal. Might depend on your area, but around here, they have plenty of options for just dumping.
This exact problem is why I love my burn barrel. But that's not an option in some parts of the country, of course.
FattyArbuckle
21
12
I like the HF/Craftsman/SnapOn analogy – very understandable.
Still not sure what I'm going to do. Wish I could get real feedback from Titan chipper owners.
With much of my purchases I get used (cars, tools, etc.) and fix. Here (SE Penna.) used chippers and other attachments seem to sell for ~80% of new regardless of age or condition. Hard to rationalize used and hard to afford new.
FattyArbuckle
21
12
Burning not allowed here. We used to natural compost except when using for heat.
I have a couple of neighbors that use wood chips so that's the plan.
WI_Hedgehog
Apr 24, 2024
1,130
1,647
They can be spendy. I got hydraulic infeed instead of gravity--the first time I fed a whole tree into it I stood back and watched it go, then thought, "I should have this on video." It's crazy to watch a whole tree (minus thick limbs) fold up and come out the top as garden confetti.
GrumpyFarmer
5,252
Unfortunately I don’t have a solution just some perspective…maybe not helpful?🤷‍♂️
A chipper is one of the implements that do one thing, but they do it very well(at least mine does WC68).
I have a woodland mills and very happy with it. I also considered woodmaxx when I was in shopping/buy mode. I did not consider DR based on my very limited times that I have seen DR implements…the ones I have seen seem bolted together, vs fabricated. (Similar to swisher brand mowers
vs something with a fabricated deck (big box store vs home owner pro/commercial grade).
did not consider a a DR based on my volume / scope of work. I have several wooded acres at my residence and another 37 separately (most of it wooded). I don’t use my chipper much but when I do it use for a day or more and I don’t want to fool with renting. I believe my frequency of use will only increase when we move to the farm.
To me it’s a volume of work and frequency of use question if not want to pay someone to take care of it or rent.
I avoided a chipper for a long time creating brush piles for wildlife or burning…that’s fine until I’m a small parcel you have brush piles everywhere and it’s so dry out you can’t safely burn or too wet to burn with out supplements…it builds up from there. So at that point what the alternative if you don’t buy one? How much and how often?
the one thing I would say though if using and only one tractor and go with PTO type, how moving the work to the machine? I sort of wish I had a standalone so i could bring the work the chipper with the grapple. If I had a stand alone unit, and extra help, then I could have someone chipping while I haul the material to it. (OTOH India want another engine to maintain🙄). That would be more efficient. As it is I make piles where i will chip then separately attach the chipper to the tractor and park it to run the chipper. It would be more efficient with stand alone tools not IMO.
