BH75 Backhoe hyd lock
Mac from our Navy
B7800, LA402, BH75
Nov 17, 2025
Waynesboro, TN
My BH75 backhoe on my B7800 tractor has worked perfectly since I bought it in 2005. I accidentally overfilled the hydraulic reservoir after replacing the filters and fluid. After operating it for about an hour, I shut it down in a field, on a hill, with the stabilizers down to keep it in place. The right stabilizer would not raise when I went to move the tractor. The lever that operates it would move only in one direction, down. I appeared to have a strong hydraulic lock. To move it out of the field, I bled the stabilizer line while jacking it up with a farm jack. After getting it back to the barn, I removed enough fluid so the reservoir level was correct, but the stabilizer control still was locked so that it would only move in the down position. I talked to our local Kabota dealer hydraulics mechanic and he stated that overfilling could not result in what was happened, and that what I was describing couldn't happen at all. But it did. Huh! The valve moved freely after the backhoe sat unused for a couple of weeks, but the movement of the stabilizer was sluggish and weak, suggesting to me that maybe air was in the lines, but when I bled the lines, I got only fluid, no air that I could see. After bleeding, the valve again was locked up when in the down position again. I'm thinking of maybe air trapped in the valve, but there isn't any bleed valves on the control valve, and the line is pretty much impossible to get to with a wrench. Anybody have a fix or any good ideas? I really need my backhoe before winter sets in here. Thanks...
6,264
My BH75 backhoe on my B7800 tractor has worked perfectly since I bought it in 2005. I accidentally overfilled the hydraulic reservoir after replacing the filters and fluid. After operating it for about an hour, I shut it down in a field, on a hill, with the stabilizers down to keep it in place. The right stabilizer would not raise when I went to move the tractor. The lever that operates it would move only in one direction, down. I appeared to have a strong hydraulic lock. To move it out of the field, I bled the stabilizer line while jacking it up with a farm jack. After getting it back to the barn, I removed enough fluid so the reservoir level was correct, but the stabilizer control still was locked so that it would only move in the down position. I talked to our local Kabota dealer hydraulics mechanic and he stated that overfilling could not result in what was happened, and that what I was describing couldn't happen at all. But it did. Huh! The valve moved freely after the backhoe sat unused for a couple of weeks, but the movement of the stabilizer was sluggish and weak, suggesting to me that maybe air was in the lines, but when es inlI bled the lines, I got only fluid, no air that I could see. After bleeding, the valve again was locked up when in the down position again. I'm thinking of maybe air trapped in the valve, but there isn't any bleed valves on the control valve, and the line is pretty much impossible to get to with a wrench. Anybody have a fix or any good ideas? I really need my backhoe before winter sets in here. Thanks...
Ply
Its not air. I am thimking return or supply line not properly connected. Slso make sure thec3pt lever but is full down.
6,379
have you checked the stabilizer lever connection? Pull the cover off and see if it looks like it is adjusted like the other side. maybe the connection loosened and it slipped a bit.
edit: having looked at the parts diagram, it doesn't appear to have any adjustment in the rod connections. Pull the cover anyway to see if you can get the rod to move freely. you could simply have something stuck in there.
2,588
You can try this:
Put that stabilizer on the ground.
Mark the hoses and cylinder so you can get them back where they went.
Remove the hoses from that cylinder and put them into a bucket.
Operate the valve to move the cylinder up and see if oil comes out of the proper line. Then operate the valve to move the cylinder down and see if oil comes out of the proper line.
Report back what happens
Mac from our Navy
B7800, LA402, BH75
Nov 17, 2025
Waynesboro, TN
Ordinarily I would agree, but all of the valves are ganged together with shared inlet and return ports. And it locked up again only after I bled the lines to raise it, using the jack. Now, after the tractor/backhoe has sat unused for two days, the valve lever moves normally, although I have not yet started it to see if it actually moves the stabilizer. I'll do that a little later and report back. (Cutting, splitting, and stacking firewood right now...)
Mac from our Navy
B7800, LA402, BH75
Nov 17, 2025
Waynesboro, TN
You can try this:
Oil comes out the proper lines, but slowly. I only did it with the lines cracked, not into a bucket. I'll try it again with them completely off and catching it in a bucket. Now, after the tractor/backhoe has sat unused for two days, the valve lever moves normally, although I have not yet started it to see if it actually moves the stabilizer. I'll do all this a little later and report back. (Cutting, splitting, and stacking firewood right now...)
Mac from our Navy
B7800, LA402, BH75
Nov 17, 2025
Waynesboro, TN
Nope, but thanks. I removed the cover as one of the first things I did to see what's going on. All of the valves are ganged together with shared inlet and return ports. And it locked up again only after I bled the lines to raise it, using the jack. Now, after the tractor/backhoe has sat unused for two days, the valve lever moves normally, although I have not yet started it to see if it actually moves the stabilizer. I'll do that a little later and report back. (Cutting, splitting, and stacking firewood right now...)
6,264
You need to start thinking in terms of circuits and refine your diagnostics. When the stabilizer is locked up do the other functions work correctly?
2,588
I FORGOT to state that the tractor needs to be running when you test this flow out of the hoses!
