Gearbox oil - am I smarter than Kubota engineers?
WI_Hedgehog
Apr 24, 2024
1,128
1,645
Milwaukee, Wisconsin, U.S.A.
Not really. Kubota provides the option to the user when it comes to front axles so there's not much to debate there.
I *think* what I learned is to use UDT2 in the front axle because it maintains viscosity far better than gear oil, eXpecially in Wisconsin seasonal temperature changes (snow!! to hot!).
MOOTS
MX6000
Jun 27, 2019
2,227
2,823
Canton, Georgia
Thats a lot of good info, now, ya wana tell me what it means in real world uses,,
All oil is slippery. Some are more slippery when cold and some are more slippery when hot.
I think.
Delmar
G1900 / Kubota BX
Sep 24, 2015
183
14
Bluegrass State
Well, I guess y'all have dashed my hopes of receiving a "Smarter than a Kubota Engineer" certificate. I do appreciate the feedback, though - especially the folks who interpreted the replies from guys who obviously sat in the front of the classroom. Like N3BP, I've got a few years of experience with these gearboxes and gear oil has always worked well. I'm likely to keep using it.
TheOldHokie - I agree. Keeping an eye on the seals is probably more important than oil choice. Pretty much every failure I've seen is because owner didn't notice a slow leak until they heard metal-on-metal sounds coming from running it dry.
5,222
Don’t despair…...I have faith in you sir….I think you are “Smarter than a Kubota Engineer"
(at least the one that designed the “middle of the hood gas tank”. ;) 🍻)
Delmar
G1900 / Kubota BX
Sep 24, 2015
183
14
Bluegrass State
Thanks, Runs With Scissors. I'll take it!
I once worked on a Kubota mower gearbox that was packed with grease. Severely neglected with deteriorated seals and someone just packed it with grease. It had obviously been operated that way for many hours. It was a bear to clean up but the gears and bearings were all fine.
Mark_BX25D
Bx25D
Jul 19, 2020
2,102
1,606
Probably not. Uneducated speculation vs. engineers who do this for a living?
I'm probably betting on the engineers.
I'll go roll my eyes somewhere else.....
I think it's good to be inquisitive and look for the nuance in things.
Only if you have the necessary education to understand those "nuances".
Otherwise, it's likely a case of "a little knowledge". That expression exists for very good reasons.
For something as complex as lubricants, it's not just a matter of, "thicker is better!".
11,755
Perhaps that engineer was smarter than you think. Perhaps he/she had invested in a company making fuel storage/dispensing systems such as those made by JDI, knowing that customers would soon tire of climbing up on the front wheel and balancing a 5 gallon jug on the hood. They also figured that the need to refuel in -10°F weather, or waiting 10 minutes for the fuel to trickle out of a container and into the fuel tank, or the complete loss of any feeling in the owner's fingers would eventually drive even the most stubbon and cheap owner to a better solution. Been there and done that. 😩
11,755
The OP isn't trying to build a rocket to get him to Mars and back. 😂 In addition, many implement manufacturers recommend 80W-90 gear oil for the gear boxes and Kubota offers a choice of UDT2 or 80-SAE 90 gear oil for the front axle of many tractors (see highlighted text below).
As I mentioned earlier, the local Kubota dealer uses 85W-90 for the reason that the OP mentioned i.e. fewer issues with oil leaking past the seals.
KubotaJim47
Kubota B2601
Apr 3, 2026
How do I know which oil I have in there? If the dealer added one type can I top it off with the other? Meaning add UDT2 if there is 80w90 gear oil in there now? Or vice versa.
7,103
Loosen the drain abd let a smsll drop or to out as a sample. The difference is obvious.
You csn mix them in any proportion buf I see no reason to do that.
And just because I hate these discussions Kubota specifies SUDT2, SAE 80, od SAE 90 gear oil for the front axle in these tractors. No mention of UDT or SAE 80W90 gear oil :devilish:
nbryan
Jan 3, 2019
1,417
936
Hadashville, Manitoba, Canada
My ancient 5ft M5-4 rotary mower blew its seal, drip drip went the 80w90, so shut it down while investigating how to replace the main bearing. Ugh.
Research also pointed me to replacing the oil with JD Corn Head Grease.
Solved, mower still goes like hell, no more leaks, nice quiet operation.
So there.
Just another bush hog gear oil story.
Thanks.
KubotaJim47
Kubota B2601
Apr 3, 2026
I was just looking to top off with the same fluid as what is in there now but not worry about if I get it wrong. I’m no expert in different oils so I’m not sure it will be super obvious to me but I’m assuming you either mean color, viscosity, or smell or maybe all 3.
I see now the manual states SAE 80 - SAE 90 not 80w90. My mistake thanks for the correction.
7,103
Smell would be #1. Dont worry - it does not matter which you use and that includes SAE 80W90.
4,147
Well, I guess y'all have dashed my hopes of receiving a "Smarter than a Kubota Engineer" certificate. ….
Don’t despair too early…. perhaps Industrial Engineer and Pres-Elect Maria Croina Machado of Venezuela will give you hers…. 🤣
