PTO hydraulic pump
2,419
local dealer doesn't have any suggestions on that option
If you have an existing pump that you need to replace there should be a nameplate on the pump somewhere telling you the flow and pressure at some RPM(s). You can then select a pump that fits onto the PTO shaft that gives you the same performance.
If you are trying to add a pump on the PTO to drive the backhoe and have no idea how the pump needs to perform then you need to get information together on what the backhoe needs to operate satisfactorily and safely. The flow will just be for how fast the backhoe will extend and retract the cylinders. The pressure will determine how much force the backhoe can exert but there may not be much choice on that. I glanced and one site showed three flow rates (maximum) but all developed the same 2250 PSI maximum pressure.
TLC
B7610HSD
Apr 3, 2011
Circleville, Ohio
Thank you
2,419
Another suggestion is to ask about it at a local hydraulic design and repair shop that might know a lot about what is needed- assuming you are not that interested in figuring it out yourself.
Good luck.
5,740
2,419
I don’t see where anyone said it was complicated. I just gave him information on how to select the pump he was looking for.
But thank you for providing that link to what should work.
