Sorry for the silly question but, Do you have 3 phase on your street?Like most people, I obviously have single phase power,
If so It might be worth it to have the power company run it to the house...
In my situation with low HP machines, Bridgeport and Harig surface grinder, I had good results with static converters. They were an inexpensive solution , easy to wire and served me well.Static phase converters suck.
No internet myth. Here are some experts explaining why. Pay close attention to Forrest Addy who is an expert of experts.Sorry, that is an internet myth, 100% not true for VFD's.
I have three of them...not an 'expert' by any means, but plenty of experience with them.
You would be shocked at the cost of that service.Sorry for the silly question but, Do you have 3 phase on your street?
It depends on the converter.In my situation with low HP machines, Bridgeport and Harig surface grinder, I had good results with static converters. They were an inexpensive solution , easy to wire and served me well.
Now if I was running large industrial machines running lots of hours and hogging big chips the rotary converters would have been the way to go.
I'm sure your right.You would be shocked at the cost of that service.
There are a multitude of advantages to 3 phase induction motors. Ask Google for a list.I'm sure your right.
So, what is the advantage of a 3ph machine?
Other than they are cheaper because very few folks can power them.... (correctly)
I mean, for a hobbiest guy wouldn't it be more practical to buy a single phase machine OR swap out the motor for a single phase lump?
That has to be possible... No?
Just to clarify…How many converters did you use? If more than one why?I had the same problem with my lathe. The motor was wired for 400V three phase star configuration and I changed that to delta, making it 230V three phase. I use Toshiba inverters for the conversion from single phase 230V to 230V three phase. I am not using variable frequency but only the soft start (programmable) that I also use on the hydraulic pump of the pillar lift. I simply have the on/off function and the speed change is using the various gears.
In the class of motors abd inverters we are talking about an inverter produces 3 phase output. Period. You only need one to convert 240v single phase input to 240v 3 phase output.Just to clarify…How many converters did you use? If more than one why?
I can swear when I was discussing the use of small single phase input converters to get three phases out I was told by a power electronics engineer that more than one would be required but I may have been understanding this incorrectly or maybe it was to change the voltage also and go to three phases. I was just discussing it casually as in ”is that possible and what people are doing now”.
I worked at an electric motor (large industrial motors - usually 4000V 3 phase) that also designed and built adjustable speed converters to drive the motors. So they would commonly use “more slices” to increase power output where a slice was similar to a slave drive that all communicated to each other through a master control slice that was the “brains” that controlled most everything.
As a mechanical engineer they were interesting devices that just made my job a bit more complicated due to the various speeds the motors could be operated on (two pole motors on 60 Hz power usually went through the first critical shaft speed and ran fine at 3600 RPMs but not well at 70 to 80% synchronous speed for example)
Yes sir, you are probably right about that. Hence my question.BTW - your understanding of C is waaaay off the mark.
Two options
Phase Technologies Home | Variable Frequency Drives and Digital Phase Converters | Phase Technologies
POWER ELECTRONICS, POWERFUL SOLUTIONS At Phase, we understand no two installations are exactly the same and our manufacturing process reflects that. We treat every order like a custom order, meaning every unit that leaves our facility is hand built, fully tested, and approved for installation.www.phasetechnologies.com
I bought a digital phase converter 20 years ago.
Set it up in my shop wired the output to a 3 phase panel.
Wired my whole 3 phase shop to the panel .
I have moved twice since then and it all came with me.
I have had zero problem with this setup.
It comes with a price though. 20HP converter in 2005 was $6000.00
I was running 2 CNC machining centers, compressor, grinder, lathe etc.
If this is going to be your only need for 3 phase....
eliminate the need.
Single Phase Conversion Kit for 1 HP Bridgeport Motor | SP2SP-WW
Bore and Borach of Pully Not Required. See the product descriptions below to ensure you're selecting the right product.machinerypartsdepot.com
So you are using "Method 1” in their description?My mill is 2hp 220v 3 phase, powered with a Phase-a-matic PAM-300 solid state 1 phase to 3 phase converter.
It has run flawlessly for over 30 years.
I pulled the power from an unused 30a 220v dryer circuit.
I'm told that this setup will provide less than full power, but I have never been able to detect any evidence of that.
I also run my 220v 3 phase diamond/alox tool grinder on the same circuit, but not at the same time.
I have a 12-4 rubber cord from the converter connected to the mill through a 20A 250V 3 phase twist lock cord cap, and just disconnect it from the mill and connect it to the grinder's cord with the same cord/cap.
I forward/reverse power tap with large taps (1"-8 UNC & 1"-12 UNF) and have taken heavy enough cuts to make the belt slip with no problems from the converter.
I suppose if I had it to do over again, I might go with a VFD, but this was cheap & fast to acquire & hook up.
I think I installed it & was up and running in less than an hour after the converter was delivered.
We do not.Sorry for the silly question but, Do you have 3 phase on your street?
Is that stamped on the motor somewhere?There is different wiring for industrial 3-phase, Wye (likely in your application) and Delta. You might verify what you have first, I've seen some funky things...
You can.build a 2 HP rotary phase converter yourself using a used 2HP 3 phase idler motor and a handfull of capacitors. Its cheap, provides clean 3p power and full load motor HP. Just plug the Bridgeport in and it will operate exactly as it was designed. Did you get one with a variable speed head? If not thats the only advantage to using a VFD.WOW guys, thanks for all the info.
Looks like I have some “homework” to do.
So this whole “power tapping” thing looks to me like it would "hurt the machine”.
From a beginners perpsctive, doesn’t that "instant reversing" damage the gears of the machine?
I have seen lots of videos of people doing it, but I still have a hard time wrapping my head around how in the world that can be OK to do to a machine. And would I miss not having the capability???????
I’m a “Cherry Boy” when it comea to 3 phase power.
I’m still reading through the plethora of material provided by y’all, and have not ruled out anything yet.
@TheOldHokie do you have any recommendations for building one of these? (i.e. brands to get or stay away from? Are they loud? )
The bottom option is very intriguing. I currently have a 1 HP machine, so “technically” I would be upgrading my HP…..(although it’s a Chi-Com motor so…..)
Attention VFD proponents……..
Since I have no experience with VFD’s, any reccomendations on brands? I obvouisly went to Amazon and started looking.
Lots of “cheap options” but they almost seem “too good , to be true” ……
Thanks for the help/advice/opinions so far though…….![]()
