Diesel mushrooms
4,191
Biologicals live in the interface between the water and the fuel. The Fuel is used for food and their body-wastes are what create the problem in fuel and corrosion in tanks and systems.
Removing the water is a start…but that does not get rid of the spores that subsequentlygerminate and start things anew.
The only ”real” solution for fuel storage tanks is to use anti-biologicals.
Jass
L2501
Dec 26, 2016
27
Auburn,ca,usa
I have a 2016 L2501 in CA and have had an issue causing the motor to bog down on the slightest of grade or workload. The tractor does not get a ton of use and has about 400 hrs on it. Could this diesel mushroom phenomenon be the cause or the bogging down, and might the Biobor JF additive mentioned be a corrective measure?
Jass
L2501
Dec 26, 2016
27
Auburn,ca,usa
I purchased some of this Biopor JF additive and put some in the fuel tank. After a week or so I changed out the fuel filter and drained a bit of fuel from the lines and now my L2501 runs great, so I believe this stuff made a big difference.
BiggB
B7100D, B2030 front blade
Mar 20, 2026
64
38
New York
almost everyday it seems we hear about diesel fuel contamination. so I cut and paste for s&g's i put together the following for those who have been lucky so far.
Quote:
Diesel bug is contamination of diesel fuel by microbes such as bacteria and fungi
. Water can get into diesel fuel as a result of condensation, water penetration AND adsorption from the air
if you buy biodiesel this form of diesel is especially hygroscopic
sulphur in diesel helps prevent the bacteria. so if you are a low sulphur diesel user this natural preventor is no longer present which used to help prevent
what is diesel bugs / fungus?
microbes that live at the transition between water and diesel fuel some call these microbes diesel fungus / diesel virus or diesel snot.
is a potential risk to your engine's fuel system, can cause serious damage and eventually lead to engine failure.
if fuel subjected to variations in weather and temperature or your fuel has been stored for more than aa few months then there is a considerable danger that your fuel may be contaminated.
contamination from water
water is the most common contaminant usually building up from condensation.
biodiesel is hygroscopic (it attracts water molecules from atmospheric moisture) so doing NOTHING is no longer a best practice.
Low sulphur diesel is more highly susceptible versus high sulphur diesel as the sulphur kills the bacteria
Fuel containing any amount of water could seriously damage your equipment’s fuel injection system and would make it more prone to breaking down.
Diesel has inherent bacteria in it. A little water from the atmosphere or contamination starts the growth of this bacteria and the mushrooms. It now breeds and multiply quickly and can easily and completely plug and block a fuel system.
The internet is full of these pictures and stories.
The bacteria will form a layer between the fuel and the water.
It breeds there producing waste which manifests itself as slime, sludge, black/green snot.
Once the bacteria colony grows to a certain load level it will settle out and fall to bottom of tank plugging hoses, filters, increases corrosion, damages pumps, etc.... sometimes very very quickly as the colony sinks from this layer between water and fuel to the bottom of your tank getting sucked into the internals.
Eventually engine will stop and may let you restart, maybe run for a short period of time then kaput!!
there are many things we can do.
- keep fuel clean, tank full, filtered and fresh and seasonally suitable.
- Since water sits at bottom of the system drain regularly if there are drain taps, replace filters more frequently than in the past
- avoid temp changes that minimizes condensation (frequent short trips from heated spaces to unheated work places if a big no-no if trying to avoid problems)
- am am now embracing tank cleaners, biocides, filters more than ever. Never used them in the past but the world has seemed to change
- I added a fuel polisher to my storage tank.
all stuff the larger fuel users have learned in recent years. Just sharing with the smaller tractor users who don't get a lot of hours on their machines so maybe not yet seen this sh@t first hand yet.
cheers
Had that on a sailboat the tank was deeply buried it was a real PIA to clean out
Mark_BX25D
Bx25D
Jul 19, 2020
2,112
1,614
Here this new guy asked a question and y'all ignored him!
For the sake of any future readers, to answer the question, yes, it could very well be the cause. Take a look at your fuel filter and see if it has boogers in it. You'll need to clean out your tank and replace the filter. Even if you kill the stuff in the tank, that won't remove the boogers.
I just had this problem, and sucked out the tank with a diesel pump from HF. It was not pretty.
Here's what the filter looked like:
aemsee
G5200
Jul 27, 2021
14
14
Fayette New York
I will add a little PSA. This same contamination that damages your fuel system can damage your body as well. If working with this fuel avoid getting it in to cuts. It can cause infections at the very least. In your blood stream can be deadly.
I got a bad metal sliver under my fingernail while teaching a diesel fuel class and ended up losing the tip of my finger. Dr said it was due to the fuel. Ironic that I had been teaching my techs about these fuel critters for years and to protect themselves. Case of do as I say, not as I do.
Blue2Orange
Apr 3, 2025
415
290
Bayview Township
Anyone using the PowerService brands of water, sediment, biological treatments? BioKleen looks to be for cleaning out the critters. Clear Diesel more for maintenance and prevention. Considering using the Clear Diesel couple times a year for prevention of contaminants.
Sawdust&Shavings
Apr 25, 2023
210
250
Stafford, VA
I do, it’s readily available here and they make two products as a preventative measure depending on the time of year.
Power Service Diesel Kleen:
  • SILVER bottle in SUMMER
  • WHITE bottle in WINTER
Blue2Orange
Apr 3, 2025
415
290
Bayview Township
Have been using PowerService anti-gel/cetane booster during the winter months for +25 years. Haven't had any gel issues. Our cold nights even back at the beginning of this millennium rarely drop below 0F. Either it works as advertised or didn't really need the additive. Sort of trust the brand based on use. Minimal hours of seat time on the BX. Less than 100 hrs per year. The BX sips diesel. IRRC, 8 gallon tank. Topped it off in late March. Still over 1/2 tank full. Bit concerned about the fuel sitting around for extended period. Not bio-diesel, but still don't like the idea of old fuel without some form of "stabilizer".
