Best tractor for snow moving in gravel lots
Lowlysubaruguy
b7800 l4701
Oct 3, 2025
Big Island
Ok follow up to my first post same subject different direction.
If I focus on one thing that seems to be the biggest task I do with my tractors its snow relocation. While some of its plowing the bulk of this are two gravel lots in two commercial settings while one of these has a 300 foot long paved two car width driveway I have to clear about an acre of hard packed gravel parking lots in total. And what plow accessory would you recommend I do not think a blower is a solution these are parking lots. And the total weight needs to be under 6500 pounds.
If there was a tractor that fits this scenario it might be the real solution for my tractor hunt. It will need a quick change loader bucket if im not using its loader bucket for this task maybe a larger tractor will do this with a loader bucket and not snow implements im not opposed to updating an older loader and bucket.
Snow when it’s deep is wet heavy snow so not the dry fluffy stuff you guys see in some areas. I dont even touch it when its less than 4 or 5 inches unless mores coming or it is going to stay around.
Plowing with a truck is tough first they gouge up my lots something fierce I can figure a couple grand in new gravel if im plowed out twice. Ive given up on this and just use my L4701 with a rear box scraper and the loader bucket. Trucks with plow blades cant work close around cars and were automotive shops. Many of these cars are inoperable. And after its all been pushed to areas its got to by piled up at some point. Which a truck can only do so much or id just buy a plow blades cant for one of my wreckers.
Any input here is great.
9,379
The best R530, R540, R630, R640 and a snow pusher
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,637
2,093
Western MT
I like rear blade offset for just pushing snow off the road. I use the bucket to move piles in areas where it has to move. Do consider chains at least for the rear. Snow blowers can be pretty cool to blow the snow way off the road. I make multiple passes with some a foot or so off the ground with my rear blade to push the snow farther off the edge when required.
You should watch some youtubes and decide what you want to try.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,808
2,202
Near Lancaster, PA, USA
I had a blower and it was great for driveways but awful in parking lots. Blowing the same snow more than one time compacts it too much for the blower to handle. Many people have fastened pipe or shoes to their blades / plows to work on gravel. The only experience I have with gravel was on our driveway before it was paved. I used a rear blade turned backwards till the gravel froze solid.
Bee-Positive
BX1880, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
455
440
Amsterdam, NY
Most all of the large shopping centers around here use snow pushers but they have paved lots.
Even on gravel I'd go for a pusher and adjust the skids accordingly.
Bearcatrp
Mar 28, 2023
1,026
643
Minnesota
Pusher on gravel moves gravel. Found this out the hard way on my class II driveway. I have a 6 for rear blade, turned around, and angled using the top link, to where it’s almost straight up and down. Doesn’t move the gravel. On the wet heavy sticky snow, go over it a few times or use the bucket. Your rear blade at a 45 degree angle should protrude a little on both sides. My 1880 is 4 feet wide. The 6 foot works great for me. Not sure the width of your so buy appropriately if you go this route. Good luck.
9,379
I'm still really confused as to how much snow you get in Hawaii????
nbryan
Jan 3, 2019
1,342
869
Hadashville, Manitoba, Canada
I'm on a back 80 walking trail in this clip, and does quick work of our 700 feet of driveway, and large parking/turnaround lot. Along with a couple miles of trails. It's light and agile for working around heavier bush and forest, and handles well enough for me without ballasted tires and/or chains.
Starting winter I usually have the BH77 on the back. Wetter, heavier, slicker snow then can sometimes leave me spinning helplessly if a wheel hangs up off a shoulder or something. Mr backhoe to the quick rescue out. Otherwise it's blower/boxblade combo as the box scraper is awesome for snow mass moving into blower range/path for final clearance.
Oops, here's the clip...
9,596
The big island top mountain snows. we did our training just below at pocholol (not sure the spelling). About the only place I know of that snows in Hawaii.
I think you mean Pohakuloa. It snows up at Mauna Loa too, but despite going up there for work many times I never got to see any snow up there.
9,596
Heck, an L6060 or MX6000 with a blower on the back and a hydraulic angle pusher or blade up front would be about as multi-functional as you'll find. You have a challenging task with the different issues you're facing, and perhaps there isn't a perfect solution, but only a decent one.
There are two changes I'd consider to my setup shown below. One is a pull forward 3-point blower which has the only advantage of not needing to look over one's shoulder but some significant downsides. The other is a hydraulically angled snow pusher rather than a snow blade. I think they offer more capacity so that has some appeal. That said, I've used the setup below for four years and have very little to complain about.
