Place your bets on inoperable L3350DT front axle...
CaverDave
1950 Ford 8N Kabota L3350DT/Woods DuAl 195
Nov 10, 2025
Stuart, VA
Despite no response in my earlier thread, decided the gamble was worth it to me... and pending daylight operation, have committed to purchase. He's also throwing in: a printed WSM, all the components to convert the pin-on FEL to QA, and packings for the lift cylinders (one has a slight rod seal weep).
Looking at purchasing an L3350DT with Woods DuAl FEL and front axle inoperable... meaning the driveshaft couplings are both good, the "output" spins when in 4WD, but the "input" at axle spins with fingers/no resistance.
Seller is a bud, this was his "keeper", but ended up with 2 others (30 & 65HP) and is pricing as "2WD tractor" in the 7500 range.
Tractor specs:
  • All fluids changed
  • Three new tire tubes
  • Good tires. New seat and battery. I have the grill and headlight assembly, but one of the mounts is broken.
  • One set of rear remotes.
  • Third function hydraulics on loader.
  • Wheel weights
  • 2508 hours
  • Shuttle shift
  • Woods Dual 195 loader
This is the tractor/tool needed for maintaining 88 (very hilly) acres... a mile-ish of gravel driveways/ditches, downed trees, light AG, etc.
My question is what are the next most likely "fuses"/weak links inside the front axle?
Appears parts availability is decent(?) and plan to do the work myself (should have any specialty tools required)
Looking at the exploded, appears the input is direct to the pinion?
As stated by the seller and confirmed by myself:
  • the output from the rear spins fine when engaged
  • while lightly worn, the splines on the prop shaft and couplers are serviceable
  • the input (pinion) of the front axle will spin freely by hand with *NO* detectable gear mesh felt​
This leads me to think the ring and/or pinion is roached?
Unless someone thinks the R&P could be rotated by hand and some other hard parts outboard might also be to blame?
Once it's here, will be opening it up to find out 😬
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,063
1,511
Pittsburgh
I got $5 folding cash on squirrel spunk clogging the axle vents at 375:1
9,782
Unlike smaller models that require you to pull the hub and axle and multiple other parts to get to the guts, this one you pull a couple mounts' and a cover and you'll have your answer staring you in the face.
CaverDave
Nov 10, 2025
Stuart, VA
My assumption was the ends would still need to be disassembled to pull the inner axle shafts out of the side gears, before that removable center section would come out, correct?
9,782
Well dang, looked at it way too quick, you might be right on the mark with that... 😣
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
482
116
NZ
Even if all the gearteeth were gone, I'd expect some residual noise/feel and a handful of metal in the oil. Just to broaden the scope, I'll bet that something inside has been removed :)
CaverDave
Nov 10, 2025
Stuart, VA
Agreed... Was able to spend a few minutes earlier today checking.
Raised the front tires off the ground:
drivers side took more effort and could feel it spinning parts...
pass. side spun freely, as if zero gears/shafts connecting it...
pinion input continues to spin with moderate effort and no movement from spinning the tires
Unfortunately, will be "several" weeks before I have time for exploratory
JohnDB
Jun 9, 2018
482
116
NZ
Its a real pity that people turn these old 4WDs into 2WD, but having rebuilt the front axle of my M4500DT (55hp one generation older and a size heavier than yours) I can understand why some decide to forgo the cost and difficulty getting replacement parts. I got a lot of help from this forum so I'll watch this thread with interest to see what you find and do. Looking forward to the next installment and getting @hagrid 's $5 :)
9,782
What your explaining sounds like you have an axle issue on one side.
If one side has parts missing the drive will not power the other side.
Might be a simpler fix than the diff.
I would pull the side that's easiest to turn first.
