L4400 3 point lift bounces with mow deck
bsamot69
M9000, m9540, m6060, L4400, SVL 97-2
Jul 31, 2018
152
Grapeland, Texas
My l4400 3 point lift bounces when I raise mow deck. Makes it difficult to mow if you can imagine that. Rest of hydraulics function properly. Yes, it is a front loader. The front loader does not bounce with a load.. any suggestions?
5,746
Check the adjustment on the position control feedback linkage.
If thats correct and its still "bouncing" I would suspect bad seals on the 3pt lift cylinder.
bsamot69
Jul 31, 2018
152
Grapeland, Texas
Considering the condition we found the loader cylinders, I figured as much . Is the 3 point cylinder accessed from the top?
5,746
J dio not know but the WSM should have detailed instructions. Does the 3pt leak down if you raise an implement and shut the tractor off?
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,817
2,225
Near Lancaster, PA, USA
Do some Googling. A bunch of that series had jerky three point hitches. Kubota cheaped out allegedly to make plain Jane tractors more affordable. That was when they began eliminating the fender mounted starboard grab handles and covering the bolt holes with stickers. 🥴
Edited cause I cunnit spel rite
