Walk Behind Snowblower Recommendations
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
379
290
NH
Looking for a used two stage around 30" wide with electric start and would like to get inputs from anyone as far as reliability, parts availability and whatever other comments of various makes.
Looking for a two stage probably around 30" wide with electric start.
Thanks
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
124
121
Lakes Region, NH
Thanks
I have three two stage snow blowers all with electric start (which I never use because they start easily with the pull cord). All have been reliable. They range in size, blowing capability, and degree of ease to "wrestle" around. Details below:
Ariens Platinum 30" is the newest (about 9 years old) and definitely the strongest, will blow anything you can force it into. It will loose traction before it can bog the auger and fan, but can be pushed hard thru anything. Quite heavy and not easy to manually pull back instead of using one of the two relatively slow reverse gears. It's my main blower for tight areas around buildings that I cannot get to with the tractor mounted 63" front blower. It has a metal chute, but I did break the gear that rotates the chute.
Troy-Bilt 24" from Lowes (about 10 years old) and the weakest blower of the fleet, but used as my deck snowblower where it permanently resides. It does have to deal with large snow banks from the snow avalanching from the metal roof. Dealing with these snow piles sometimes requires first breaking them up some with a shovel. The Ariens would have no trouble with these, but it is not possible to get it on the elevated deck. The Troy-Bilt is light enough for very easy manuverabiltiy such as rapid manual backing up. I never use the reverse gear. It does however have a plastic chute which has yet to break, but I'm sure it would it it had to pass a lot of big ice chunks.
Craftsman 28" (at least 15 years old) Has been a good strong blower and is now the backup to the Ariens. It is relatively easy to wrestle around. It has a plastic chute which had cracked several times when throwing big ice chunks and I repaired it with bolt on metal strips. I finally lined the plastic chute with sheet aluminum and that solved the breaking problem.
In conclusion I would strongly recommend you look for a machine with a metal chute. Electric start is not important unless you physically have trouble dealing with pull start. Also, size matters when "wrestling" the machine around which depends on your own physical capability. The Craftsman 28 is probably the best balance of blowing capability and manuveurability. I know you can still get parts for the Ariens and Troy-Bilt, but not sure about the Craftsman given the overall demise of Sears.
imarobot
Apr 18, 2025
379
290
NH
Thanks. One of the uses would be for cleaning my deck. I will have to get up three stairs so weight will be an issue. I was thinking of using a ramp to get it up the steps.
I will also have to deal with the snow from the metal roof piling up on the deck so can't go too small.
bobnic
Mar 7, 2025
124
121
Lakes Region, NH
My deck is 10ft off the ground so I have a lot of steps, thus the deck snow blower stays on the deck and spends the off season in a plastic shed on the deck along with extra propane grill bottles etc. A ramp would probably work to handle 3 steps and a snow blower of the size and weight no more than my 24" Troy-Bilt. If your steps are wide enough between the railings I could even see driving the 30" Ariens up the steps in low gear if it could get enough traction on the ramp and it wasn't too steep.
Bearcatrp
Mar 28, 2023
1,312
959
Minnesota
I had great luck with a cub cadet I had before moving on to my BX. Parts are at my local kubota dealer. Mine was top of the line with power steering. Had triggers on both sides of the hand grip to help steer. Would buy again if I needed one.
imarobot
Apr 18, 2025
379
290
NH
Thanks guys, very helpful.
The more I think about this something around 24" might be easier to handle getting onto the deck. I was thinking something bigger to do sidewalks and some driveway but maybe don't need it.
These days snow is wetter and heavier than the storms of the good old days. Any recommendations on HP?
Any thoughts on the green snowblowers? I see plenty used for sale and wonder why. Being as they are the color of money; I'm thinking parts may require more green that other brands.
