Front weights - LX2620
BruceMc
BX25D LX2620
Sep 27, 2014
54
122
Fairbanks, AK
I have a new LX2620 that could use some additional weight on the front end. On my BX25 I welded up a weight that hung nicely off the front 'bumper' but with the design off the LX, I can't switch it over. That front plate/bumper is too recessed, and the loader arm cross member is located so that there isn't any clearance. Kubota makes a bracket for suitcase weights on the LX, but explicitly state you can only use it with the loader removed. Anyone come up with a better solution?
SDT
Apr 15, 2018
3,636
1,362
No.
I bought the front weight bracket and 5 weights for my similar B3350. As stated, neither the weights nor the bracket can be installed with the loader mounted.
FWIW, three weights can be mounted on the frame without the weight bracket on the B3350 (not the replacement LX 3310) but not sure about your LX 2620. In any event, front weight bracket or not, no front weights can be mounted with FEL in place.
Shouldn't need front weights with FEL in place.
2,927
Could you just pick up something heavy with the front end loader?
BruceMc
BX25D LX2620
Sep 27, 2014
54
122
Fairbanks, AK
Unfortunately, like the BX, the front end of the LX is still light enough to lift the wheels sometimes when plowing. Not as bad as the BX, but it is a pain if you get too aggressive in float.
Bearcatrp
Mar 28, 2023
1,309
956
Minnesota
Is your blade digging in that grabs and lifting your front end? I spun my back blade around, then adjusted the top link so the blade is almost straight up and down but just enough not to dig in. Learned real quick digging into my class II driveway. Moves snow great now.
BruceMc
BX25D LX2620
Sep 27, 2014
54
122
Fairbanks, AK
It's the front plow blade if you're running in float. I have a long gravel driveway that has some small wows and dips, so I prefer to set the blade to follow the contour. The BX had the same problem. That first winter with the BX I loosened up the trip springs and switched to the rubber edge on the plow and that helped some, but I found the most effective solution was to run the front blade a few inches off the surface and let the rear blade do the final scrape. I welded up a 125# weight bar for the front and that helped, too. There are spots, though, where snow needs to be pushed rather than dragged and I'm finding the front end of the LX still unloads enough off the front tires that you lose directional control.
FTG-05
Jul 21, 2013
343
188
TN
I used railroad fish tie plates or rails:
