Rear Wheel Noise
ChuckCastiglione
L2350
Aug 24, 2019
15
NW PA
My 1994 L2350 4wd started making a screeching sound coming from the left rear wheel. Kinda sounds like a brake shoe spring fell off and if rubbing on a brake drum in a car. I've never had the rear wheels off. Any thoughts would be greatly appreciated.
Thank you
Chuck
10,720
I would say your most likely cause would be a bearing failure.
Jack up that side and spin the wheel and see what you have going on.
CJCastiglione
L2350DT
May 20, 2019
Greenville, pa
I jacked up rearend and both rear wheels are off the ground. They spin freely and make no noise. When tractor is moving on the ground then I can feel a thud as the rear wheels rotate. The sceeching noise has mostly went away. There is no noticeable difference in how tractor runs. I just feel a thud in the seat coming from the rearend. No grinding or crunching sound. The thud happens at least once every wheel rotation. any thoughts?
10,720
Have you checked the Lug nuts?
But I'm still thinking you have a bearing issue.
The way the rear ends are built, sometimes if you take pressure off of the wheel, you can unload a bearing that's causing the problem, and that makes it tough to locate the issue.
CJCastiglione
L2350DT
May 20, 2019
Greenville, pa
Is the rearend lubricated by main hydraulic system? Or it seperate?
2,927
If you have two piece rear wheels you might have looseness at the rim to center plate bolts. Bolts can be loose or there can be looseness even if the bolts are tight (nut bottomed out and not tight against anything).
ChuckCastiglione
L2350
Aug 24, 2019
15
NW PA
BINGO! Before I tore into the axle I decided to do a little more investigating so I dug out my stethoscope. The motor was making too much noise so I decided to coast down my driveway hill with the motor off. The noise was easy to hear now. It was coming from left rear so I jacked up the left side and could feel a little movement One of the four outer rim clamp bolts was just a little loose. Tightened it up and we're all good. Thank you!
