Do You Like A Clean Hole?
WI_Hedgehog
Apr 24, 2024
878
1,219
Milwaukee, Wisconsin, U.S.A.
I'm changing over from the pin-on grapple to pin-on bucket and heard a gritty sound while pulling a pin. The BX is used for landscaping so bucketing dirt and stone is common, and the bucket is used to back-drag dirt so the pivot points are sometimes buried, though rock dust takes a real toll on the grapple pins.
The pin looked good and I didn't feel anything abrasive, but grit seems to reside more on bushings. Both the pins and bushings are slightly worn despite overly frequent greasing.
I realize some here wax their tractors, do you clean and inspect your pins and bushings?
(I'm going to be doing that on the off-season of each implement)
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,040
1,447
Pittsburgh
Depends on how many empty Miller High Life bottles are scattered about me.
5,245
Short answer, no. Maybe I should.
I do grease every 10 meter hours and put in new until it comes out. That’s all I’ve ever done to non-sealed greasable pin type joints on farm/construction type equipment. Haven’t had any problems with premature wear yet.
Not a big fan of pristinely cleaning excess grease off greasable pin joints subjected to dirt and/or rock dust. I’m aware some think that indicates lack of care, and I’m OK with that. I also don’t wax my tractor, but probably would if it was stored outside or the paint started chalking. I’m somewhat concerned about my equipment’s appearance, but it’s not a high priority. YMMV.
WI_Hedgehog
Apr 24, 2024
878
1,219
...I do grease every 10 meter hours and put in new until it comes out. That’s all I’ve ever done to non-sealed greasable pin type joints on farm/construction type equipment. Haven’t had any problems with premature wear yet. Not a big fan of pristinely cleaning excess grease off greasable pin joints subjected to dirt and/or rock dust. ....
That's a good point, in retrospect the new grapple should have been greased, used 10 minutes, re-greasted, used 30 minutes and re-greased...instead of just greased and used. I think the dust from drilling holes in rocks got in there and did some damage.
I'm still new to all this....
