Restrictor Valve Install
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
388
298
NH
I put restrictor valves on my flail mower tilt and shift cylinders which helped a lot. I'm wondering if I connected them right. The restrictor valve body has printing on it for the connections at each end - 1 at one end and 2 at the other end. Does it matter which end, 1 or 2, connects to the rear remote?
2,985
I am guessing that it does matter or why would they number them.
You can probably find information about the particular valve you have by searching for it by name and model number.
Again logic would be inlet would be #1 and outlet would be #2
3,773
2,334
Most restrictor valves have built-in check valves so they only throttle the flow in one direction. The documentation that came with them should tell you which end is which.
imarobot
Apr 18, 2025
388
298
NH
I don't have any info on it but will look into it when I get the make/model # off of it.
I'm wondering if because it's adjustable that it may be a needle rather than a check valve.
3,773
2,334
I may have been wrong about 'most'. Flow control valves are available in bi- and uni-directional control. The one shown below is a uni-, the check valve allows uncontrolled reverse flow, similar to our 3ph lowering speed control. The bi- doesn't have the check valve.
2,985
Would that type of valve (shown above with a check valve) work in a double acting cylinder system? I don’t think so since the tank return side would be blocked (if a valve is installed in both lines)
10,801
Yes it's free flow in the reverse direction.
So flow from 1 to 2 is restricted by the adjustment as the check valve is closed.
Flow 2 to 1 is unrestricted via the check valve being open.
7,039
Massive overkill and expense. All you need is these hydraulic adapters.. No guessing, no adjustment, no confusion.
2,985
Unless you get the restrictor fittings mixed up with regular fittings and install the restrictor in the incorrect position. NOT that I would do that :rolleyes:
imarobot
Apr 18, 2025
388
298
NH
This what I have, it doesn't have a check valve so I'm assuming it restricts in both directions, which it does appear to do.
I have the end labeled 1 conected at the rear romote connector,. I don't know if this even matters being as there is no check valve.
7,039
That is an adjustable bi-directional flow control valve. It will work but is expensive overkill.
imarobot
Apr 18, 2025
388
298
NH
Yeah, but not if you get them for free!
OntheRidge
Nov 1, 2020
490
582
Question about these- For a grapple, or a snowplow, would I need one for each direction? Plow has 2 cylinders, if that matters. Also, I would assume I would need for both implements? Thank you much!
7,039
For fixed orifice restrictors you only need one total.
