B8200 alternator
WanderOn
Kubota B8200D, B300A FEL
May 27, 2024
173
416
New England NSW Australia
Hi everyone
Doing the very long drive home and my mind wandered to my tractor.
When it's at idle the battery light comes on and doesn't go off until revs get to about 1200rpm.
I know with our landcruiser the volts and charging capacity jump up considerably around 1200rpm but it's not discharging the battery at idle.
I've been meaning to have a look into it but don't want to go down another rabbit hole. I do have a very special talent for it
Anyway, thanks for having a look
Andrew
2,900
Check that the belt is tight and/or not slipping. It may be so old it is tight and slipping.
Hugo Habicht
G1900
Jun 24, 2024
1,504
2,158
Ireland
The operators manual says "if the light continues to glow above idle speeds...".
I think this suggests that it is normal what you are seeing. The work shop manual may have more detailed information but I could not find that for download.
With the worn belt: my tractor had been sitting idle for a while and the new belt lost tension very quickly due to wear. I believe it was the rough surface of the pulleys due to rust. After grinding them smooth the wear problem went away.
WanderOn
May 27, 2024
173
416
Thank you
I will check the pulleys. It has been sitting for quite a while
WanderOn
May 27, 2024
173
416
Hey all,
Finally updating this thread.
Got my self sorted and went through the manual.
Dynamo tested fine, just need to get the revs up to get it going. Never had a vehicle with a dynamo.
Thanks for the help with it.
7,512
Hey all,
Thanks for coming back with a solution. It will help others. Nice when the answer is so easy !!!
