1999 L3600 GST Shuttle Shift safety switch location
3,450
2,026
Does anyone have a diagram that shows where the shuttle shifter's safety switch is located for a 1999 L3600 GST?
Remove bolt 050 and I think you'll find your switch under cover 030. You do know there's also a PTO safety switch and apparently another lock out?
dougfiat
L4300
May 2, 2018
10
Etna, Ohio, USA
Thanks- yes I know there is more than one. I have to jiggle / hold down the shuttle shifter for the safety switch to start the engine. So. I am pretty sure thats the one.
L35
Jun 13, 2010
611
595
CT
My tractor has almost identical switch and location, I just had to adjust it in the last 2 weeks. My switch was held in by a Phillips head screw. The location of the switch was fixed but was able to re-bend the switches lever so it started making contact with the shifter again.
