I bought a used soil screener with 4 leveling jacks. With normal use / wear and tear, the plastic handles on the jack cranks have broken, making cranking difficult. The only replacement option is to replace the entire weld-on jack (cost about $70 each). This does not include cuting off the old and welding on the new. The jacks are otherwise quite servicable despite being a bit beat up. There must be some option for replacing the plastic handle grips. Mabye 3d print new ones? Lathe out of wood/metal? The ends of the cranks shafts are mushroomed to hold them on, so I'd have to cut the new grips in half lengthwise, place them around the shaft, and then screw or wire the clamshell halves together. Or cut off mushroom and cut threads on the shafts to accept a nut/washer. Pics below to clarify the issue.
This forum always amazes me with the depth of knowledge and experience of its members. Looking forward to your creative soultuons. Thanks!
