Question for the colective
5,613
Boys I need some ideas because I know someone has already done it some place. Has anyone come up with something to put a boom pole on the FEL? Remember I dont weld si any ideas would be super
11,757
I decided to go with a turnkey solution. I'm ashamed to admit that I've yet to use the boom pole but that will change shortly as the new sheds/pole barns go up.
Could I have made my own for less money, maybe. But at $1,258 I felt it was worth the cost, even with shipping to the local Kubota dealer. It'll last forever, and when I think of what it would cost to pay a company to put up the buildings that I'm planning and building myself, the cost of this implement doesn't really mean a whole lot.
Here it is on the MX
GrumpyFarmer
5,212
Do you have a hitch for a 2” receiver on your bucket? (Bolt on or have some one weld it?)
If I were putting a boom pole on, I’d use the hitch and use 2” tube stock. I think length of your pole (don’t make this weird😉) also might suggest other ideas?
Edit: just saw @McMXi post and I like that idea better assuming you have SSQA. If not just buy a new tractor with SSQA.
5,430
How long do you need it to be, and how much weight are you projecting to lift?
Without a welder, I’m thinking of a series of clamps or some holes (2-3) that go through a square tube and bolt to the top of your bucket?
Or possibly a round tube that bolts on the top/bottom of the bucket and is held in place by 2-3 U shaped brackets (Like the ones used on automotive exhaust’s)
or this.
5,613
RWS, Im not looking at a lot of weight and I know the farther out you go the less you can lift, but only a couple hundred pounds at most. Rafters and I dont get up and down a ladder to well any more, so I thought maybe lifting them up, hence the boom pole in the bucket. At least getting them up and in place.
torch
Jun 10, 2016
2,881
1,127
Muskoka, Ont.
I made one:
(build thread here)
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,977
Near Lancaster, PA, USA
The lifting ability with a pole 6' in front of the loader would be very limited. If you had something like the one that torch made, and had it vertical and sitting on the floor before picking the load, it could lift a tremendous amount. Or, you could rent something like I used when I built my shed:
11,757
I have a snatch block and an 8,000 lb winch on my Jeep. You've got me thinking about mounting the winch to the front of the M6060 and running the "cable" up to the snatch block attached to the eye at the end of the boom pole, and turning my tractor into a crane of sorts. 😂😂😂
@torch has a chain hoist doing the same thing, but a winch would make for a lot of fine control from the cab.
chim
Jan 19, 2013
3,278
2,977
My smaller winch has been plugged into the receiver on the 4240 a few times. It isn't anything special. HF with wireless remote. Here are a few pix when there were three 700#-ish A/C compressors that needed to go from the below grade boiler room to a trailer at church.
torch
Jun 10, 2016
2,881
1,127
Muskoka, Ont.
I've thought about doing that -- getting the extra chains out of the way would sometimes be nice and a pulley at the top would also maximize use of available height -- but think I would want the winch control available outside the cab more than inside. Maybe something with a wired or wireless remote control. I tend to work by myself and ideally I'm not in the cab when trying to hook onto or place objects.
As noted by Chim, I strive to keep the pole as vertical as possible and planted on the ground. That photo shows the rear blower as counterweight, but I prefer to have the backhoe on and plant the outriggers too. Makes it a very stable configuration. McMXi has a much bigger and heavier tractor so he can get away with using the FEL hydraulics for the lifting. Not so much with my little B7100!
If I ever need more height, I will fit legs/outriggers to my boom pole assembly so the weight is still on the ground rather than on the tractor's front axle.
chim
Jan 19, 2013
3,278
2,977
I haven't found it today but about a week ago I saw a YouTube guy had a DIY crane boom on a trailer that was connected to a receiver hitch on the front of a jeep (i think). He picked a beam and drove it a short distance to set it.
3,925
2,434
or this.
That first picture belongs in the You Must be Old thread. I must be, so here. I took my old car, '66 Mustang or '75 Malibu can't remember, to a muffler shop for a muffler and tail pipe. The kid is finished except for tightening the clamps. Hits the first one with the impact. Zzzt, zzzt, pop. Takes that one off, puts another one on, zzzt zzzt pop. Three times!
barts
4wd B5100 w/ FEL, box blade, JD110 TLB, WC68 chipper, log arch, brush mower.
Feb 10, 2015
129
119
Lopez Island, WA
We just made a box beam from 2x lumber, supported it w/ chain and straps and used it to hoist trusses onto our new shop.
pigdoc
G1800S L2500
Aug 19, 2022
403
349
SE Pennsylvania
When I was working on a pole barn crew (in my early 20s!), we had a removable boom that just hooked on the bottom lip of the FEL bucket. It was adjustible in length. Like, a 3" square length of square box steel sliding inside a 4" square length, through-pinned at variable extensions. At the outer end of the 4" section, there were two 3/4" rods attached with pins. Other end of those two rods hooked to the upper, outer corners of the bucket with pins. We could set 60-foot trusses on top of a 16-foot sidewall with that setup, no problem. Nice thing about it was that it was easily stowed on the tractor trailer for transport to the next job.
[Can't find any pics on google...]
-Paul
