Preface: I have spent about three hours reading posts here including Torch's build and cant seem to find this answer. If I missed the answer somewhere I apologize in advance.
Ok as the title says, I'd like to run my B219 FEL from the pressure from the hydraulic block on the side of the tractor. I bought a B6000 tractor that was junk with a B219 FEL. What I didn't realize was the pump runs the opposite direction on the B6000. Until I get that sorted I've seen a few posts where people have ran them off the side block. Yes I know it will be slower. But a slow loader is better than No loader right? Anyways, my question is, I still have the original control valve for the B219. Part number: 70050-00072 hopefully shown below. Can I simply hook this valve to the block or do I need a new valve with a power beyond outlet? Side question, my valve has BYD stamped on it. But it seems to be above a port that's not tapped. Can I simply tap that port IF BYD is needed?
Of course any front pump replacements or control valve replacements links or part numbers are welcome here. I do have a front spline adapter/shaft/bearing that I believe was for a mower that I don't mind modifying.
